Question about Motorola Mobility V220
People can't hear me!
My Motorola V220 is being mental. I am able to receive and send text messages, and I am able to receive incoming calls as well as make outgoing calls. However, whomever I call can't hear me! I can hear them just fine, but they just hear a gentle crackling sound. What is going on??
  • 983 Answers
There is no problem with your handset ....This problem is due to the loose contact by the mic ...
if you are good at opening the handset then just open the handset and then have a check near the mic ....
then try reconnecting everything .......
if problem persists then replace the mic with the new piece ...
the mic too much cheap to purchase .... but while purchasing just tell your handset model and take the compatible mic .........
after replacing there will be no problem at all from any end .......
your set is fine ... you dont have to worry too much ...
just spend a very very little money to take a new mic and replace it..
if you are not good at opening then just visit the technician ..........
any doubts reply me
i am always here to assist you
thank you
bye
Dnt forget to rate the solution .............
Posted on Apr 29, 2008
My Motorola Photon Q will not receive or send texts or calls, what can I do?
I would check with sprint to see if your account is up to date. Otherwise, I would suggest going to your settings and see if you can update your phones's prl and profile. go to settings, tap "About phone", Tap "System updates", then tap each option. Good Luck!
Dec 05, 2012 | Motorola Mobility Sprint Photon Q 4g Lte...
Hello I have a Motorola V220 and although the phone is working and receiving calls I can't send or receive texts anymore. The ones i have recently sent are waiting in my ountbox and I know that people have...
Dear Littelbod1,
It related to your Mobile signals , just go to near Service centre ,they will fix this problem by reload the software of your mobile phone.
Cheerup
Mar 07, 2008 | Lands Phones
Cannot send text msgs "status 95"
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Aug 27, 2012 | Motorola Mobility V220
No voice received on incoming calls
try useing it on speaker phone..if it works there then the problem is in the speaker..it is eeasaly replaced also you can try and do a software upgrade..
Oct 07, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Cannot send or receive text messages
TRY resetting your phone
go to main menu, settings , master reset, 000000 /1234 if u didnt change ur security code,
GOOD LUCK
Apr 28, 2009 | Motorola Mobility V220
How do I delete text messages from Inbox on Motorola V220?
first press menu, select messages, then press menu button again, scroll down to cleanup messages, select, then scroll down to which box you want to delete and select. done!
Mar 25, 2009 | Motorola Mobility V220
Text Message Inbox setup
you must insert the message center number in the message settings(setup)....
to get the message center number follow the steps below...
1. call to your network provider customer care
2. ask them for the message center number
3. note down the message center number
4. insert that message center number in the message settings
and save it...
one this completes it will not ask you for the setup while sending messages or when you open the inbox..
any doubts reply me..
thank you
bye....
Dnt forget to rate the solution........
Apr 14, 2008 | Motorola Mobility V220
No audio on outgoing or incoming calls
dakarjohn - you need to replaced the speaker on the phone.
GUEST - replace the speaker on the phone.
SAEFUJI - you need to replaced the flexcable on the phones, contact your mobile provider or your local operator for assistance.
Mar 11, 2008 | Motorola Mobility V220
Not receiving or sending texts?
After spending quite a while talking to the techies and no solution, my friend said she had the same problem with her phone and she turned it off and then back on ! It worked for me !!!
Mar 07, 2008 | Motorola Mobility V220
Motorola V360.. i need to empty the memory
you need to reflash the software on the phone
Sep 14, 2007 | Motorola Mobility V220
Motorola Mobility V220 Logo
136 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
