Question about Kitchen Ranges
Put the door back on my oven
Hi, model # PRG3000P. Took the oven door off to move it and am not bright enough to get it back on. please help. thank you for your time
  • Amber Hardin
    Amber Hardin Apr 29, 2008
    It's PRG3010, not Prg3000
  • 121 Answers
If you merely lifted it up off the two spring loaded supports, you should only need to slide it back into the bottom of the door...You may need to use pliers to move the supports into a horizontal position (normallaly open position). If you actually removed the supports from the springs...it will be very hard to replace, because the springs are hidden.
Posted on Apr 29, 2008
Oven door hinge
Could you take a photo of the oven, the door and the hinges and show us?
Feb 14, 2014 | GE Microwave Ovens
My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Feb 01, 2010 | Tappan Ovens
F9 on Maytag range MGS5770ADB
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Dec 23, 2008 | Maytag MER6769 Gemini Electric Kitchen...
Whirlpool RBS305PDQ light does not turn off
It's possible, but is door installed correctly? Push in light switch and see if error goes away. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Whirlpool RBS305PDS Electric Single Oven
REPLACING AN OVEN DOOR
HI thanks for the question. the locking clips were not locked, when you pulled out the oven door . lay stove door on the floor. take one hinge push towards the floor. lock small clip to the hinge ,do both. now re-install door. pull door towards you . unlock the locking clips. both. now close the door.thanks the appliance doc. please rate my answer thanks
Oct 08, 2008 | Ovens
Can Get Door Back On
Just managed to put the doors on. Do the bottom door first. There are 2 little spikes on the bottom of the door. You need to slot them into the holes in the frame. Then make sure that the little metal flaps on the top of the door fit UNDERNEATH the inner door frame. Screw together.
Same with the top door, additionally add the trim on top.
Thanks to solution #1 - I've literally been fuffing about since yesterday evening, I was about to call out the engineer! :)
Jul 19, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Oven door back on
My Jenn-Air oven door also comes off to clean. To remove the door you just open it slightly (to the first position) and lift the door up. To replace it just pull the hinge out about the same angle (about 15 degrees) and slide the door in place on the hinge levers and close the door.
Apr 29, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Need help putting GE oven door back together again
they're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Jan 09, 2008 | Kitchen Ranges
Whirlpool oven door
Push the hinges out till they click once. At this point, get your nails or screws ready. Use a screw driver and wedge the hinges further apart. When you see the hole in the hinge appear, put the nail in it to hold it open. With both done, drop door in place; open door slightly, and remove nails.
Oct 17, 2007 | Ovens
Kitchen Ranges Logo
184 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
