Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Replaced 2 resistors one burnt up. please help
Replaced both resistors r7011 and r7015. r 7015 burnt up. would this be from bad soldering or incorrect cable reconnection? or would it be wrong part or another problem?
  • toolfreak316 Apr 29, 2008
    i replaced 2 resistors that had burnt up on panasonic pt53tw53. after i reconnected all the cables and turned the set on, the resistor for r7015 burnt up, the set shutdown and flashed 3 blinking red lights.
  • Vista Electronics May 11, 2010
    see previous post......................T.
    Second Expert solution needed ??
  • Panasonic Master
  • 8,617 Answers
They would only burn if your convergence ICs are bad so if you didnt change the ICs with the resistors they will keep burning.
Posted on May 18, 2008
Burnt smell blush picture
Maybe High Voltage Transformer, you can have a board replaced easier than buying a new set.
Dec 22, 2007 | Samsung PCN5425R 54" Rear Projection...
How to fix panasonic hdtv stk-392-110
This requires soldering and de-soldering skills and frankly it is an Electronic Technician's JOB.
Nov 13, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Pioneer sa-1050 2 burnt resistors, cannot read
where exactly are these resistors located? any idea about the circuit board resistor numbers? sometimes burnt resistors do not go completely bad and is still possible to measure their values. why not take them out and try measuring their values. otherwise u have to b very specific about the rsistor numbers
Apr 05, 2010 | Audio Players & Recorders
Panasonic TV projector PT 4743G
yes the convergence ics will blow that resistor
Jan 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
PT-53TW53 resistors needed
They are 2.2 ohms, 5%, 2 watts.
You can try digikey.com or radio shack.
Apr 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Parts for panasonic pt-53tw53g
r7011 = 2.2 ohm 2 w...
r7015 = being researched....
Partstore.com ...........................................T.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Toshiba 46wh08b projector television
Doug, convergence circuit is failing, involves removing one of the boards, replacing the convergence IC`s and probably a couple of burnt resistors, not a "layperson repair", requires soldering experience, accurate voltmeter to find the bad resistors, etc. I would suggest calling a tv tech for this repair, questions? e-mail me back BMW Rider
Jan 09, 2008 | Toshiba 46HM95 46" HDTV
No power
Solder any / all bad solder connects.While doing that,Look for
overheated areas in power circuits,caused by bad capacitors,
resulting in burnt/open resistors,shorted diodes,etc,.........T.
Nov 13, 2007 | Sharp 27H-S60 TV
Blue convergence will not move left or right
look at the convergance board it will be the one on the left there re two stk semi-conductors tward the back of the board. most likly one of them are bad but sometimes the soldering can be faulty. look for signs of cold solder if so just resolder and should be good if not also look for burnt resistors. it will be obvious finding the stk 's can be done by using google and just type in the stk # finding the resistors you might try calling panasonic to find the part #by telling them the location of the burnt resistor. good luck. mind you that the soldering of the stk (semi-conductors) you will want to use a heat sink on each terminal you solder otherwise you take a chance of burning the conductor befor you ever get to use it, if you have no exp. soldering i wouldnt sugest trying it !!!!
Oct 17, 2007 | Panasonic PT-61HX40 61" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
