Question about HP PSC 2175 All-In-One InkJet Printer
The scanning devise (the light under the glass) will not go all the way across
When you turn the PSC on the light will move about a inch from the right and then it goes back and all you hear is a click, click, etc. Is there anyway to reset this? I think it is out of place. The belt that it runs on looks okay. Any suggestions? Is it worth fixing if I can find anyone who wants to be bothered or is it better to buy a new one?
Thanks,
KK
  • 158 Answers
It is only out of alignment so it is better to have it serviced than disposing it off .
Posted on May 04, 2008
When i try to make a copy it comes out all black and when I try to scan something it is all black
Check the scanner bulb - it's suppose to light up when you copy or scan. Look inside the scan bed and as you copy or scan, it should light and move across the bed.
Feb 01, 2011 | HP PSC 1610 All-In-One InkJet Printer
Sharp AL 1457 Flashes code L 1. I have read about the scan lock on here and have turned it to the unlock position but it still does not work. It is definitely turned to "unlock" and continues...
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 25, 2011 | Sharp AL-1530CS All-In-One Laser Printer
I am getting a blue line on my scans when utilizing the feeder
The feeder sends the original across a small piece of glass. The scanner stays in one position as the paper runs across it rather than the scanner moving and paper staying still. The little piece of glass is probably a 1/2 inch by 12 inch glass. just clean that strip of glass. use alcohol. there is probably some whiteout on the glass. It will appear as a dot. When the paper runs across it, the dot is run across the whole page causing the line. if you cant find the strip of glass, run a scan and try to see where the scan light sits while it's running. Clean everywhere where the light sits.
Jan 15, 2011 | Office Equipment & Supplies
The light flashes L and the a 1 repeatedly on my AL-1631copier and won't print the page.
Sep 24, 2010 | Sharp AL 1631 Copier
When I turn on my 2410 printer the hourglass stays on endlessly.
try uninstalling and reinstalling
Don't forget to rank the advice!
http://www.aa1consulting.com
Jul 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
Hp psc 1210 all in one
try to clean your glass of scanner. bye
Mar 11, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
