Question about Canon imageCLASS MF6550 All-In-One Laser Printer
WILL NOT MAKE COPIES
HELP....I have unplugged the unit, cleaned the unit, wiped the metal connections with an eraser. I was told it might be the shutter not releasing. What can I do?
  • Arcadian Duran
    Arcadian Duran May 11, 2010
    try hitting it on the front side, sometime that will help, i did that to one here and that indicates that something is sticking. im not saying its a solution, just a quick fix. something is sticking perhaps it is the shutter. on the laser.
    swiftly hit it and see. as i said its not permanent solution, but a quick fix, you might have to take it in for repair since the shutter is sticking. if thats the case.
  • Arcadian Duran
    i think its mostly the laser, the module is very cheaply made. Staple were giving these machine away to customers that buy alot of product from them. the laser are going bad, ive just checked one and no laser is coming from the machine.
O MY SOUL IT WORKED! I've tried everything before for months... unplugging, new cartridges, servicing, etc. I've always avoided jarring an electronic item, but hitting the front fixed it! A couple of open-palmed smacks above the paper drawer, and it printed this very page.
Posted on Jun 16, 2008
SC220 Ricoh MP2500
I got an new email server and it has worked for a week but now I can't get any new information on facebook
Dec 09, 2013 | Ricoh AFICIO MP2500SPF -...
Aficio 1018 dirty copies
Remoe the image unit,remove the OPC drum ,clean the opc drum cleaning blade(if necessarry change),remove the transfer unit clean the transfer belt cleaning blade,and clean the polygon glass.
Jan 31, 2013 | Ricoh Aficio 1018 Printer
My graphic card not working properly
hi'' trey to install it properly , unplug unit then pullout v.card then clean terminals with erasers and then wipe with clean dry cloths and insert it again and start installing. i hope this can help you.
Jul 12, 2012 | Computers & Internet
I have Panasonic Workio DP-2310 copier and there were multiple lines the length of the copy .I cleaned entire copy and drum area and installed new toner cartridge now the copies are coming out blank , no...
check you drum charge connection between drum unit and developer unit, two metal strips at back that contact when the two unit are closed. none or bad connection means no charge and then blank copies
Feb 01, 2010 | Panasonic Workio DP-2310 All-In-One Laser...
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
Turn off the printer, and unplug the power cord. Remove the cartridges, then the printhead unit, clean the printhead in look warm water GENTLY. Dry completely, clean the contacts with an eraser GENTLY. wipe contacts with tissue, then re-install back into the printer, add the cartridges, so an alignment and a clean, then print.
Jan 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Cyclone blender - on light blinks and it won't operate
Had this problem couple of times. pushed the power cord in the blender as if there is lose connection inside. It worked.
Jan 03, 2010 | Black & Decker Blenders
How do I clean the metal screen? Do I need to replace any filters at any point?
if the metal screen is removable, run under warm water and gently brush with damp rag
if no removable, unplug unit, wipe clean with damp rag
May 29, 2009 | Ecoquest Flair Air Purifier
Copier quality is so bad
you might have the scanner checked!
Jan 12, 2009 | Panasonic Workio DP-2500E Copier
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
HP Laser Jet 3055- "No print cartridge" message
This could also happen due to the censors.
Try these steps.
1. Take all the papers out from input tray.
2. Open the cart door & take the cart out,and let the door be open.
3. Turn Off the printer.
4. Clean the metal contacts on the cart.
5. Reinsert the papers & the cart.
6. Turn the printer on.
This could resolve the issue.
All the Best!!!!!!
Feb 27, 2008 | HP LaserJet 3055 All-In-One Printer
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
97 people viewed this question
old marine
old marine
