Question about MicroBoards PF-2 InkJet Printer
Pf2 ink cartridege recognition issues
I use microboards ink and they are within the expiration date but it still won't load after printing 3-5 discs
    Problem Solver:
  • 30 Answers
Sounds like you have either a defective ink cartridge, or the sensor that recognizes the cartridge is either dirty, broken or out of alignment.
Microboards will help you out at no charge if your printer is still under warranty. Otherwise you can contact an authorized Microboards repair center like
Posted on Jun 17, 2008
Microboard pf3 is not printing with NEW EXPIRED ink cart.(v101c black and v102c color). please how can i make it work
I had a HP that wouldn't print because the Cart. were past a certain date. I finally just went in to the pc and set the date back, and the Cart. worked fine.
Jun 02, 2014 | Office Equipment & Supplies
Microboards PF2. Loading jams after about every 6 DVDs. Has to be freed manually and then restarted. Jams after about another 6 0r so.
We have the same problem with some brands of discs. Fan the discs before you load them and/or try another brand of DVD. We like Datasafe or Datawrite
Jan 26, 2011 | MicroBoards Office Equipment & Supplies
My Microboards PF2 does not print color properly.
The next to last cartridge I installed did not print properly. It seemed like all the colors were not there so I weighed it on a postage scale and it weighed less than another new one I had. I called Microboards. They said to send it to them and they replaced it. It may not be that, but weighing it should give some indication if it is.
Dec 07, 2009 | MicroBoards PF-2 Disc Printer
Pf2 not printing red ink with new cartridge # PRF38ML
Defective cartridge, contact Microboards and they'll send you a replacement for free if there is more than 80% of the ink still left.
May 27, 2009 | MicroBoards PF-2 InkJet Printer
Single blank disk inserting wont work (Mircoboards PF2)
You may have a disc loading error. To correct this follow these instructions:
Disk Loading error:
If a disc is not loaded correctly, it could cause the out of paper indicator to come on. Press the out of paper button on the interface. The printer will attempt to load another disc. If this does not clear the error, remove the discs from the input bin. Check to see if there are any discs on the belt. Remove any discs that are left on the belt.
Lift the cover and check for any discs on the front part of the printer. Remove any discs found on the belts. Close the cover.
Next, reload the input bin and press the out of paper button. The system will load the next disc and continue printing the remaining discs for that job.
If that doesn't work, and there are no obvious jams in the transport system, I'd call support and see if they can walk you through a fix. They can be reached at:
For technical questions or support issues, please contact Microboards Technology technical support at PH: 952-556-1639, FAX: 952-556-1628, by email at or on the web at
Mar 19, 2009 | Microsoft Windows XP Home Edition
Microboards PF-2 won't load several cd´s in array
make sure the cartridge reader is no more then 1mm away from the cartridge as it slides past! also check the microswich which is ont he print head slider
Feb 09, 2009 | MicroBoards PF-2 InkJet Printer
Black ink too heavy - Microboards PF2
you can adjust the dry time. go to printer and faxes and right click select preference, there should be tabs select features then below should be advance features select that and there you can adjust the dry time and amount of ink.
Jan 18, 2009 | MicroBoards Print Factory InkJet Printer
Dvd feeding problem
The reason you are having trouble with DVD's and not CD's is that the DVD's are a little thicker or taller than the CD's. The area above the belt system has to be adjusted upward. this adjsutment is not in the manual, and is complicated. My company, Techware DIstribution, has had as many as 20 of the PF-1 and PF-2 printers running in our production and demo room. We can walk you through the steps to make the adjustment if you like.
Contact info:
Mar 24, 2008 | MicroBoards PF-2 InkJet Printer
Disc Feeding Problem
I am assuming you are using a PF-2 printer. If you are using a standard HP78 ink cartridge instead of the Microboards cartridge, the unit will only print approx 5 discs before it stops. The microboards cartridges have a security tag under the barcode label that is scanned by a magnetic reader on the left hand part of the unit. If you are careful, you can use a razor blade and remove the label from a microboards cartridge and tape it on the front of a HP ink and save yourself about $25 an ink cartridge...
Nov 29, 2007 | MicroBoards PF-2 InkJet Printer
MicroBoards PF-2 InkJet Printer Logo
281 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
Don  Farrell
Don Farrell
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
