Question about Daewoo Heating & Cooling
Unable to change the blower position, air is just coming out from the dashboard vents, moving knob doesn't change air direction. also when blower is set at 3 0r 4 unable to turn the temperature down. Temperature knob works fine at 1 or 2. I think there might be wires broken inside but not sure where to buy these wires from or what exatly are they called.
The air will not blow through windscreen vents but is blowing through every where else. makes no difference when changing the direction of the knob to the windscreen only. you can hear the air blowing but nothing comes through?
Posted on Dec 22, 2008
The fan blower, even after changing it to cool -giving hot air
i would think the vent direction control isn't moving the heater box vent , stuck in the open position so only hot air from the engine ,strip out the control panel a check that the direction control cable is connected both ends ,
May 07, 2014 | 1999 Toyota Avalon
How to repair
i'd think that the vent adjuster knob/slider is not working correctly strip out the heater panel around the control knobs and check the vent direction is working properly either stiff operation so a little wd40 on the cable would probably do the trick or some thing causing the vent itself to not move
May 01, 2014 | 2004 Ford Crown Victoria
Air regulator valve on dash for heat and AC stuck in on position. Ram 2500, 2004.
The most common problem is a stuck or faulty blend door under the dash.
Feb 22, 2013 | Cars & Trucks
My blower motor works but is not blowing out the vents on dashboard, only vents by windshield and side vents but not from dash...how should this be fixed....some vacuum hose ??
You have a loss of vacuum from the engine, first check under the hood and make sure the vacuum storage tank is not damaged and leaking and it has vacuum in it when the engine is running. If all that is ok then move on to the line that goes inside the truck and verify it has vacuum.
May 23, 2017 | 2002 Ford Taurus
The blower on my a/c on 2002 chevy trailblazer only blows from the floor vents and the defroster vents but not the dashboard vents how can this be fixed. Also, it only works on 5
It sounds like you have two problems. First a question though; Is your heating and air conditioning control on the dash automatic (has two knobs that rotate and a display screen in the middle), or manual (has two levers that move up and down for driver/passenger temp and a separate fan knob and mode knob).
In response to the vents being stuck on defrost and floor, from experience i can say that the most likely cause is the mode actuator has failed. If your battery has recently gone dead, that could have brought the problem to the surface. When the battery has gone dead, the heating and air conditioning controls relearn all the positions of the actuators behind the dash when the vehicle has been re-started. If there is a position sensor failing (which happens quite often) in one of the actuators, the heating and air conditioning controls won't be able to learn the correct position of the actuator and (in your case) defaults to the defrost/floor position.
The only way to fix that would be to replace the actuator. I would like to know what type of heating and air conditioning controls you have (manual or automatic) before i say anything on the blower only working on 5.
Aug 05, 2011 | 2002 Chevrolet TrailBlazer
I have a 1991 camaro.The air or heat doesn't come out through the front vent when switch to vent control.It only come out through the dashboard to defrost the windshield..I have bought and install a...
It is the vent control. It is located on the passenger side behind the dash. It is vacuum controlled. It can fail and not let you change the vent positions.
Good Luck!
May 09, 2011 | Chevrolet Camaro Cars & Trucks
I am unable to move selector switch from any position - something in the internal workings is broken b/c the knob moves but the air vent direction does not change? how does it work? what is the name of the...
The system runs on vacuum supplied by the engine intake manifold. The switch uses the vacuum to open/close the various doors in the system by actuating diaphrams. The default is usually defrost, and the system will blow on the windshield if there is no vacuum supplied or if there is a vacuum leak in the line or in the switch. See if you can trace the small vacuum hose that comes from the engine through the firewall and up to the controller/switch and check for a leak.
Aug 25, 2010 | 2005 Saturn ION
Heater only blows thru dashboard vents, won't defrost
chech cable on back of cluster dial some time pops of causing issue.
Jan 01, 2009 | 1995 Pontiac Grand Am
Heating & Cooling Logo
161 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
