Hand held casio tv vs digital signal
What will happen to my hand held casio tv-980 when everything goes digital?
  • allon35 May 09, 2008
    Just trying to find out if the EV-570 is analog or digital.
    Problem Solver:
  • 5 Answers
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Posted on Jun 20, 2009
  • 975 Answers
One BIG issue , like everything else that uses an ANTENNA ,will be obsolete , unless the manufacturers come out with a solution to this . hope this helps
Posted on Apr 30, 2008
Why wont my casio tv 600 pick up eney channels
I HAVE THE SAME PROBLEM BUT LAST NIGHT I PLACED THE TV NEAR THE FREEVIEW BOX AND THE TV JUST PICKED UP THE SIGNAL.A DIGITAL CHANNEL AT THAT ASWELL.NEAR PERFECT IMAGE.I DONT KNOW HOW THIS COULD BE ADAPTED TO USE THE PORTABLE AWAY FROM OFF THE FREEVIEW BOX.ANY SUGGESTIONS?
Aug 18, 2012 | Casio Portable Hand Held Tv - Model...
No vhf or uhf channels
Not if it does not have digital tuner
Dec 30, 2009 | Casio 2.5" LCD Hand-Held Color TV...
Now that we have changed from analog tv to digital, will my old 980b 2" tv work? How can I rig it to receive signals?
Your TV will still pick up analog stations (less than 50,000 watts) but for most stations you will need a D/A converter, not very portable.
Oct 30, 2009 | Casio TV-980 2.3 in. Handheld Television
Digitial reception for casio 980
You won't. Because the unit isn't likely to have an coaxial external cable input, there is no simple way to achieve this. Full-size sets not equipped for digital signals can accept the down-converted signal from a converter box that receives the digital signal and converts it to NTSC standards for older sets. Direct reception of the new signal requires an ATSC tuner and there is no way to provide that for your hand-held. It would be possible to use the output of a converter box clipped onto the antenna of your Casio and see the channels the converter box can receive but your hand-held wouldn't be very portable anymore. Sorry-
Aug 20, 2009 | Casio TV-980 2.3 in. Handheld Television
Hand held tv's: How do you get digital signal?
They are pretty much garbage. You can purchase portable digital TV.
See article here:
http://www.ezdigitaltv.com/Portable_Digital_TVs.html
Jul 07, 2009 | Casio TV-880 2.3 in. Handheld Television
HANDHELD UNIT NEED ADAPTER TO GET DIGITAL SIGNAL NEAR KCMO
To connect a converter box to a handheld TV that has an external antenna jack, you need an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 12, 2009 | Casio TV-980 2.3 in. Handheld Television
I have a Casio EV-570 hand held TV. Will this work after the switch over to digital broadcast.
According to CASIO website in Japanese, their portable TVs are not supporting Digital broadcasting and decided to cease production.
Thus it will not receive Digital broadcasting.
Although, EV-570 composite AV Input should still work for Camera, VCR, etc., I have not tried to connect to the DAC box.
My portable DVD without TV tuner worked with DAC box and now can watch digital TV program!
Jan 15, 2009 | Casio EV-570 2.5 in. Handheld Television
Are there converters 4 hand held casio 880B
A few other tips:
Nov 11, 2008 | Casio TV-980 2.3 in. Handheld Television
Hand held casio televisions
Even though it's small, it's still a TV with a standard tuner. So you could use it with a converter box if you really wanted to. You would need to connect the box to the TV's external antenna connector with an appropriate adapter. Then the TV would stay on channel 3 (or 4) while you change channels through the converter box. But just like any other set without the new tuner, once the regular broadcasting ends it won't be able to pick up digital channels.
Nov 03, 2008 | Televison & Video
Televison & Video Logo
966 people viewed this question
Top Televison & Video Experts
Electro Med Services...
