Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...Guide to Programming the ... - Download the Manual - 8 Device Learning Jumbo ...
0382,0388.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
You can find remote control codes for your TV here, click the Support tab. If the codes listed don't work, there is also a listing of compatible brand codes that you can try.
Remote control codes for your TV can be found here under the Support tab. If your remote isn't listed, try codes for the brands listed in the note at the bottom of the page.
You are going to need service code for entering into Techician realining of convergence CK all small ohm resistors near ICs 1.5 2.7 3.9 ect.. I cannot find Service code, list Need Service code to enter Convergence Pattern.Will try to find my List of service code for all TVs and list them but untill then Try Listing Looking for service Code for Toshiba.
Magnavox
0503 0675
If those don't work for you then go to this link - http://oneforall-na.com/remote.php?type=URC%203021
At the bottom in tiny print is 'get codes' and that link will open-up a new window with all the codes listed.
The remote code 31 worked on my Motorola cable box.
The REmote is for a Sharp LC-32GP1U
The code was listed under one of many for Jerold. I entered codes one by one testing the secondary power button each time.
Code 31 works fine.
