Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
SONY GRAND WEGA LCD-HDTV 50 " ( APPROX 3 YEARS OLD)
I will make it a point of counting the number of times the power/standby light blinks when the picture screen is blank but I don't think there is a pattern to number of times it blinks each time it goes off I believe it varies as does the amount of time it stays off and stays on. When it first start doing this it actually corrceted itself for a day or two and then started up again with the on off.
  • Sony Master
  • 8,617 Answers
Could be a thermal sensor problem with that model
Posted on May 17, 2008
Sony 3lcd wega engine tv screen turns black, power/standby button blinks 45 times, then screen goes back on. This repeats over and over again. Do you know what's wrong with my tv? Thanks.
First check your tv if it has standby power. if it has standby power please do count the number of blinks of red led. (it is on a sequence) so that we can walk through the steps and procedure to get rid of the trouble. if theres no stanby power, its probably the power supply. please do check busted fuse and replace with same ratings.
Apr 16, 2013 | Sony Grand WEGA KDF-50WE655 50" Rear...
My sony wega wont turn on and keeps flashing power light
Flashing of standby lights to Sony TVs are fault indications. Count the number of blinks occurs at one time after switch ON, and count it carefully. Check this link to know more about the blinking codes to Sony Brand TVs. You can get details there. You have't provided the number of blinks occurs here, so I can only guide you to this extent.
Jan 17, 2013 | Sony WEGA KDL-32XBR950 32 in. LCD HDTV
The power/standby indicator is flashing a red light and my tv will not turn on.
Flashing of the led light indicates an error code, count how many times it will blink to determine where the fault came from.
Jdvillanueva
Jun 30, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
We Have a Sony KDF-50WE655, we've replaced the lamp and housing and we still have no picture or sound. Can you help?
Make sure that lamp cover is fixed back on its position securely after lamp replacement, turn On tv to check.
If still no picture or sound then check power/standby light is blinking?
If yes, count it how many times it blinks after 3 seconds long pause and let me know to diagnose possible cause of problem.
Thanks.
Aug 01, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Cut tv off now it won't come back on its a sony hdtv wega
ok. the error codes for your model only go up to 10 blinks. Carefully count the blinks as there should be a slight pause then blink again.
Jun 22, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My tv shut off now it wont turn on on the lamp light is flashing
A little more info is required bfore we can help much. If you attempt to turn on the set, the standby light should blink a repeated code. If you can post that count here, we can use that to tell you what circuit has the problem. If that light does not come on at all, that too is good info.
Thanks,
Dan
Feb 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
how many times does your light blink because its blinking an error code pls count the blinks and let me know
Apr 29, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
