Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
So slow heating up/boiling water
Can i get any more btu's out of my propane range....maybe diff orifices???? I can fall asleep waching water boil ....so painfully slow......makes us look at new stoves.....i think this one has a 9-10k btu large burner....we're now looking at 15-16k units....i wish i knew before we bought.....dumb on me!!!
    Problem Solver:
  • 22 Answers
Find you a GASMAN to resize your orifices. He will have special drill bits to do so. If I were there I could do it for you.
Posted on Dec 25, 2009
Can my 1999 Cadillac Seville concourse overheat by mixing too much water with antifreeze??
Theoretically yes. Antifreeze has a higher heat capacity than water. Basically, a liter of antifreeze can hold more heat than a liter of water. I dont think it would be enough to cause an overheat though
May 20, 2015 | 1999 Cadillac Seville
On heat setting "low", how long before boiling starts? Assume water inside.
it may never boils on low setting that is not enough heat to BOIL guess that's why it's called SLOW cooker
Apr 14, 2015 | Sunbeam Crock Pots & Slow Cookers
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
I would like a higher BTU gas range and is shopping around for new range.
Most range manufacturers give you the but rating for there burners. I have an electric range that has a "fast boil" burner. It can bring a gallon of water to a full boil in about 10-12 minutes. I also have a commercial gas (propane) range. Its burners are rated around 33,000 btu
Nov 19, 2014 | Dacor Kitchen Ranges
What is the meaning of BTU?
British thermal unit: a unit of heat equal to the amount of heat required to raise one pound of water one degree Fahrenheit at one atmosphere pressure; equivalent to 251.997 calories. The amount of heat needed to raise 1 pound of water 1 degree F (equal to 252 calories).
(British thermal unit) Describes the heat value of fuel for appliances - the higher the BTU, the more heat available for cooking.
A Btu is equivalent to 252 calories and serves as the base unit for measuring the heat content of a fuel source.
-The Ugly Pool Guy www.wefixuglypools.com
Dec 09, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
Can you boil in a slow cooker?
Generally, with enough heat and good insulation, water will boil. Boiling is caused by non-uniform heating - some spots are hotter.
My wife's slow cooker boils even on the low setting -slowly, but it boils.
Our rice cooker never used to boil until I burned tomato rice in it (OOPs). Don't make tomato rice in a rice cooker.
Mar 21, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
Top burners are propane. we are used to propane heating really fast. this stove seems really slow. 5minutes to boil litre of water. burners are having hard time lighting.
If it is new fromt the factory, you many have the natural gas (methane) jets in the burners. You will need to check your bag of parts to find the propane parts (LP parts). LP jets allow a different fuel/air mixture to burn at the right heat. Check the owner's manual for details how to make the change.
Please rate me - Good luck.
Nov 20, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Kenmore smooth top - cooking problems
Smooth tops take a little geting used to than a coil top range....Make sure you have good flat cookware. NO GLASS COOKWARE. (ie vision ware.) Once the burner is set to high, it has to heat the glass, then the pot, so it does take about 2 min loger to boil, If you want to simmer, then i suggest bringing the item to a rapid boil, and then cutting back the heat to below the 1 on the range. and adjusting from there. All smooth top glass ranges do work in this manner. Most people can adjust to the switch, but not everyone can. there really is no problem with your range. BTW i work at sears, and i am surprised that no one helped you.
Dec 20, 2006 | Kenmore 96412 / 96414 / 96419 Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
173 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
