Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
WHERE DID MY DATA GO?!?!
When I connect my WD 375gb eternal hard drive, the computer recognizes it and installs the drivers. Also, it comes up in my "My Computer" screen has having files on it (showing 263 free out of 375). However, when I click on it to view the files the folder says there are 0bytes of data there. How do I fi this?
  • 2 more comments
  • HelpMeDrama Apr 29, 2008
    No I already "unhid" all my files. They are not hidden.
    There were a several folders there before, but now there is only a "New folder" which I created before. That folder also has nothing in it (0 bytes). That is all that shows up.
  • HelpMeDrama Apr 30, 2008
    I don't quite get what you mean. The only thing that currently shows up is "New Folder" folder which is empty.
    Previously there had been several files and folders visible when I opened the drive. I had placed these files/folders on there. Now there is only that one "New Folder" folder which is visible, which I also previously placed on the drive.
    To sum it up, the only folder showing, I placed on the drive. There are no files visible whatsoever.
  • Anonymous May 11, 2010
    Do any folders show up when you open that drive in My Computer?
    Problem Solver:
  • 9 Answers
Are possilbly the files hidden, open file then rght click, goto properties,click on it, see if they are hidden
Posted on Apr 29, 2008
  • t_daddy069 Apr 30, 2008
    did you put these files on there or were they there when you looked at the external drive?
My WD Elements SE External drive does not have its driver recognized on boot, but does only after repluging its USB 2.0 connection. How do I get the driver recognized on boot? Why does replugging work
I guess it's some kind of a problem with the way your USB port works. I have an external WD too, connected to a USB 3.0 port and definitivly it's not detected at boot, just after windows startup as a USB device.
After some initial wondering about this problem, I decided no to worry more because I use external drive for data backup and if it is not detected by BIOS makes no difference.
It might be a problem of an outdated BIOS or the USB port's driver. In my case, boths, BIOS and USB 3.0 are rather old.
You can do some reading about issue if you do a ggogle search for issue
USB 3 0 external Hard Drive not detected after Intel Communities
External USB 3 0 HDD is not detected in Windows after boot Help
Aug 06, 2015 | DMCOM Western Digital Wd Elements Se 1 Tb...
WD 1200BEVS
you can pull out the hard drive from box and connect it directly with computer see if it can recognized it, can not install drive can be due to problem with the disk FW or Hardware.
try to listen the drive carefully, is there any abnormal noise, beeps ??
hope it helps.
Apr 11, 2014 | Western Digital Scorpio WD1200BEVS 120 GB...
Blinking light flashes continually. The pc can not access the eternal hard drive. I have re-started the pc several times and the pc will not recognize the external hard drive. The WD External Hard Drive...
try to connect the usb port properly maybe there is a loose contact. and try to remove all the gadgets connected in the computer... only connect the external HDD
Oct 30, 2010 | Western Digital External USB 2.0 80 GB...
My WD doesn't appear at my computer. It have energy, and computer recognizes when I plug in, but the drive doesn't appear at My Computer
First, make sure you've downloaded all of the latest drivers and ran the installation CD that usually comes with the device. Then, check the computer manufacturer's information. Your USB ports may not be supplying enough power to run the Passport.
Jun 05, 2010 | Western Digital WD Passport 250GB Portable...
How to recover WD passport250 Data
hi...if you want to see again the files on the external hard drive i suggest you make to re-install the windows or repairs the windows you`re using or try to update the mother board drivers..thank you...^_^
May 09, 2009 | Computers & Internet
My old computer does not recognize my new 250gb wd passport I get an error that my Z drive is not logged on
Are you sure your 'old' computer has USB 2.0 support and not only USB 1.1?
You can try accessing the BIOS of the computer and see if you can change the USB version there.
Once it is recognized, Windows (XP?) should recognize it and install the drivers. If you are running an older OS, you probably need to install drivers for it first. But those would come with the drive (on a CD maybe).
Also check out:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jules
Feb 26, 2009 | Western Digital Passport WDXML800UE...
WD External Hard Drive malfunctioned & is not recognized
you can **** in western digital factory with this ugly hard drive
Dec 24, 2008 | Western Digital My Book (WDG1U2500)...
Maxtor III 500 GB external hard drive is no longer recognized by computer. No driver installed ???
Drivers are not necessary for hard drives - as long as your computer recognized it when you first installed it, you're all set. It sounds like your hard drive has failed, or become disconnected. Check the connections for IDE or SATA, and power. If they're both connected properly, listen when you power up the computer to hear if that particular hard drive spins up. If it doesn't, it might be dead.
If you have access to another computer, try installing the drive into it temporarily and see if it is recognized in that computer. If the drive has failed, you might be able to get it replaced by Maxtor if it's still under warranty. Unfortunately they will not recover any data on the drive for you; you must pay a data recovery specialist to recover any data on the drive, and this is expensive, so only do this if it's extremely important data.
Jun 10, 2008 | Computers & Internet
External hard drive not recognized
I think the hard drive is causing the issue as the two computer were unable to detect the drive.
In this i want you to disconnect the hard drive & clean the golden edges of the drive and the connctors and connect it back.
Go to BIOS menu & check whether it is detected in the BIOS or not.
If it is not detected, connect the hard drive to another computer which can boot to windows.
And run the diagnostics using the software from the WD site.
http://support.wdc.com/download/index.asp?swid=1
Error code information you can get from
http://support.wdc.com/techinfo/general/errorcodes.asp
Check with this.
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
166 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
