Question about InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector
Projector stopped working
About 1 hour into a movie it just stopped working. No power light and no fan. I left it unplugged overnight and even changed the power cord. I had also just checked the lamp hours a day before and it was only at 350.
  • 563 Answers
Hi amp422
This wouldn't be a lamp issue at all if there is no power at all on the unit.
Take of the top cover and change the fuse located on the Powersupply Board ( the one where the AC socket goes into)
Should do the trick.
Thanks for using Fixya !
Posted on Apr 30, 2008
Optoma movie time projector has a vibrating sound
Normally this sound noise is the small FAN inside. Dirty or faulty. You must open the proyector, or go to some shop repair.
God bless you
Jan 25, 2013 | Optoma EP706 Projector Remote Control
Dear Sirs, I have a BENQ PE8700 projector. I know it's outdated, but it still suits me fine. I've already changed the lamp, and this new one is 1000 hours old. I am recently having a problem:...
If the bulb on this projector is filament less then it may be a bad ballast. If it is that kind of a bulb the ballast is like the starter on a florescent bulb that excites the internal gases for light to be emitted. If it conks out, the bulb stops emitting light even though the cooling fan stays on.
Apr 30, 2017 | BenQ PE8700 Multimedia Projector
I have sony vpl-ex1 projctor and i have also changed the lamp of the projector but it still shows me the same message like change the lamp. Please advice! Thanks, Pravin Bhavsar
1.unplug power cord
2.plug back in and it should be in stand by mode.(red light on)
3.do not power on
4.on remote push RESET,LEFT ARROW,RIGHT ARROW AND ENTER(do it in less than 5 seconds)
5.after you have done this power on and go to menu and it should show lamp hours 0
6.if it didn't work just do it again, it took me a couple of tries.
Jan 04, 2011 | Sony VPL-EX1 Multimedia Projector
My VPL-VW50 suddenly stopped working a couple months ago. It turned on, the fans started, then it would stop and a red light began blinking three times. I looked up the code and found that it needed a new...
fisrt, did you reset the lamp timer? if the projector turns on again, go into the menu settings and reset the lamp timer. 3 flashes also mean that the lamp is too hot. let the projector go through it's cooldown mode and shutdown before you unplug it. remove the filter case and vacuum or blow the dust out of the filter. you can also blow the dust out of the projector (if any) with canned air. lastly, be careful where you buy lamps from. you get what you pay for. cheaper isn't always better.
Dec 08, 2009 | Sony VPL-VW50 Projector
All buttons control tv/video, remote stopped working
Unplugged it for an hour.... buttons changed.....Unplugged it for four hours and everything worked......Left it plugged in overnight and back to original problem....
Oct 02, 2009 | Toshiba 32A33 32" TV
HP XB31 Projector heat senor
Hi Marc
How do you know that the sensor needs replacement ?
Could you please give me some of the sympoms first ?
This could be something other than a sensor.
May 04, 2008 | HP Digital Projector xb31 Multimedia...
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
InFocus LP530 projector not powering on
the power supply needs to be replaced. it goes after a while in this model.
Feb 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
Mitsubishi HC1500 DLP Projector
This sounds like an overheat issue and requires return under warrantee.
Oct 06, 2007 | Mitsubishi ColorView XL30U Multimedia...
Cinego Automatically shutts off after 15 seconds
had the same problem - replaced the lamp even though it only had 632 hours on it. seemed to fix the problem - 10 hours and 4 moves later still doing ok
Jun 12, 2007 | Radio Shack Cinego D-1000 Multimedia...
InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector Logo
435 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
