RCA LYRA H125, 5 MB MP3 PLAYER "File system corrupted" error message. Is there a way to do a hard reset on this? Tried all the other fixes out here (ie; joystick,holding on/off etc.) nothing has worked.
  • jamalking2 Dec 04, 2008
    My RCA Lyra says that file system is corrupt. What exactly can I do to restore it? I have lost all my songs also.
  • Anonymous Apr 11, 2009
    WHEN I CLICK ON MUSIC OR ANY OTHER MENU APPLICATION IT SAYS FILE SYSTEM ERROR WHAT CAN I DO?
Die
Posted on May 26, 2008
File System Corrupted
Have you tried replacing the firmware on it, I believe this would be the firmware for that model http://drivers.softpedia.com/get/FIRMWARE/Lyra/Lyra-Mp3-Player-RD2760-firmware-207.shtml
Mar 04, 2008 | RCA Lyra RD2762 MP3 Player
My RCA LYRa is having issues!!!
http://www.fixya.com/support/t126039-file_system_corruption
(H115A)
Had "File System Corrupt!" message appear on my RCA H115A after a bit over a year. PC wouldn't recognize it, and it wouldn't stay turned on.
Following advice (thanks folks), I uncovered the screw under the barcode and popped the back with the help of my knife. I didn't notice that the connection from the hard drive was loose, but pulled it out, wiped everything off, and reconnected. It worked!
They don't give this at the help desk, but it seems to be a common problem with many models. Looks like the connection isn't very tight.
Jan 05, 2008 | RCA Lyra RD2763 MP3 Player
System file corrupted
Have you tried replacing your firmware? I believe the firmware for that model is here http://drivers.softpedia.com/get/FIRMWARE/Lyra/Lyra-Mp3-Player-RD2760-firmware-207.shtml but you may can get a newer version from rca's support site.
Nov 20, 2007 | RCA Lyra RD2762 MP3 Player
RCA LYRA RD2762B (4 GB ) MP3 Player
I had same issue and found a law office that filed a class action against RCA/Thompson. Here is the result:
Thank you for contacting David P. Meyer & Associates Co., LPA about the action our law firm filed against Thomson regarding RCA mp3 players. The matter was settled on behalf of the individual Plaintiff and the lawsuit was dismissed on October 10, 2007.
If you have a hard disk drive player that is experiencing a file error corrupt or similar error and you meet certain requirements, you may be entitled to a replacement unit at no cost to you. You must contact Thomson at 1-800-587-5518 no later than December 31, 2007.
Best Regards,
Shelly Coffman
Claims Investigator
1320 Dublin Road, Suite 100
Columbus, Ohio 43215
Direct Dial: 614-384-7030
Toll Free: 1-866-827-6537
Fax: (614) 224-6066
E-Mail: shelly@dmlaws.com
Website: www.dmlaws.com
Sep 30, 2007 | RCA Lyra RD2762 MP3 Player
Rca lyra rd2765a
When this happened to my unit I had to have it replaced by RCA.  Fortunately mine was under warranty at the time.  About 2 years ago when this happened the RCA rep told me that the unit has a fairly low capacity for shock.  So if you dropped it this could be the issue.
Sep 20, 2007 | RCA Lyra RD2763 MP3 Player
My RCA Lyra RD2765 MP3 Player
mp3 player says the file system is corrupt
Aug 22, 2007 | RCA Lyra RD2765 MP3 Player
File system corruption
I actually fixed this!!! Mine had been giving me the "file system corrupted" error. So, I opened it up (unscrew the screw on the back, pry the back cover off with a small flat head screwdriver or a key, etc.) and saw that the connector between the CF drive and the motherboard had come apart.
I re-inserted the cable into the groove of the connector on the motherboard, pushed the broken/separated piece of plastic that serves as a retainer for the cable back down, held it in place, and taped it down with a 1/4 inch wide strip of duct tape (taped all the way around the connector/cable to help keep it in). I put the Lyra back together and then turned it on... and it WORKED! It came right on into the normal menu! Yay!
Good luck other people, I hope that this is the same thing that happened to your player and that you can also fix it! =)
Dec 05, 2006 | RCA Lyra RD2763 MP3 Player
File system corrupted!
get a new hard drive;if no warranty; open the mp3and reset hard drive directly
Nov 07, 2006 | RCA Lyra RD2763 MP3 Player
File Sytem Corrupted!
The dreaded "File System Corrupted" error is one that comes time and time again. Did you drop the player or hit it by accident? If so, then the pin connecting the battery to the micro hard drive has probably been disconnected. You can removed the back of the player with a screwdriver, but you risk tearing off the S/N sticker. If you decided to do it anyway, remove the back of the player and then simply fit the multi-pin connector back into the hard drive. Replace the back and screw it in, and then turn it on to see if it works. I did this with my old RD2762A, and it worked like a charm. Hope this helps!
Sep 27, 2006 | RCA Lyra RD2763 MP3 Player
133 people viewed this question
 Grubhead
Grubhead
