Xerox Phaser 7300 Error U20 - Office Equipment & Supplies
    President:
  • 2,072 Answers
1. Contaminated or damaged Imaging unit contacts. - Remove and clean the contacts and inspect for damage.
TROUBLESHOOTING TIPS AND HINTS:
Imaging Unit Failure message occurs because the printer cannot detect imaging unit motion, up-and-down. The Transfer Belt drives this motion, and the Drum Contact Assembly detects it. 1. Swap the Imaging Unit Cotact blocks between two imaging unit positions. If the problem follows the Contact block, it should be replaced. 2. Open the Top Cover and defete the top cover interlock switch. The color imaging units should raise in succession, cyan, magenta, then yellow, and then all lower at once. If one or more imaging units do not raise smoothly or drop prematurely then replace the Transfer Belt assembly.
Posted on Apr 30, 2008
  • Rick Kasper Apr 30, 2008
    Try this.
    Resetting the NVRAM will reset all printer values including network, printer setup, job defaults, and color calibrations.
    1. Press the Down arrow key and scroll to Support.
    2. Press the OK key.
    3. Press the Down arrow key and scroll to Service Tools Menu.
    4. Press the OK key.
    5. Reset NVRAM will be displayed.
    6. Press the OK key.
    7. Reset NVRAM and Reset Printer NOW will be displayed.
    8. Press the OK key to reset all the settings to default.
Help with u2 code on phaser 7300
U2 is an engine EEPROM failure - you'll need to replace the main board to fix that, I'm afraid.
Jan 08, 2013 | Xerox Phaser 7300DN Laser Printer
Error u26 phaser 7300
U26 is Yellow Image Unit failure. It may be that the contacts are dirty - spilled toner?? Give it all a thorough clean, especially where the electrical contacts are - if still no luck, then a new yellow IU should solve the issue.
Dec 01, 2012 | Xerox Phaser 7300DN Laser Printer
I have a Xerox phaser 7300 that keeps telling me to install or reseat the black cartridge
It is slightly unusual for it to be the black toner cartridge (usually cyan or magenta) but this issue is quite common on the 7300. You can find a lot of information about this here.
Dec 15, 2010 | Xerox Phaser 7300DN Laser Printer
Colors do not align
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Nov 03, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300 color misregistration
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
False reading of toner cart status
Sounds to me like you actually have the wrong part number. There are more than one cartridge for the Xerox printers, They have different chips on them. One is for billable accounts, one or more than one for accounts that pay for prints. There also was as i remember a spring type clip they left off some cartridges.
So with what you have tried and the old cartridges work fine, strongly suspect bad carridges.
Dec 01, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
Error message
Cause:
This message is related to the on-board SRAM on the Print Engine Control Board Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Replaced the Print Engine Control Board,
Dec 19, 2007 | Xerox Phaser 7300DN Laser Printer
713 people viewed this question
k24674
jasbo
jasbo
