Question about Lexmark X8350 All-In-One InkJet Printer
Lexmark X8350 jams (and other problems) after ink cartridge refill
I had my black ink cartridge refilled and I once I loaded it back in the printer I had false "paper tray door" open, jams with paper curling around back roller (rear door which is cleared for jams) and print heads appearing to be printing, but nothing is on the output.
Could all of this be related to some kind of damage to the cartridge when it was refiled or is there something else probably going on? I find it strange that I wasn't having these problems until I put the refilled cartridge back in.
I'd hate to go buy a new ink cartridge and that's not even the problem.
  • amdeals Apr 29, 2008
    Did not tear any of the paper when jam occurred. Nothing can be seen as to the possibility of blocking the path. I just find it strange that all of this occurred from the false "Open Paper Tray" errors, the paper wrapping around the rear rollers, the paer comes out without anything printed, but the heads where moving like there was some output. I didn't have these problems before refilling the cartridge.
  • 101 Answers
You have a paper jammed in the path or there is something blocking the path, try to look inside carefully.
Posted on Apr 29, 2008
  • Ping ong Apr 30, 2008
    put the old cartridge back in and see if you have the same problem, check the paper tray if the spring pops up went you install the tray.
Refilled ink printer. still shows empty on the printer,s screen
Lexmark does not recommend the use of refilled/remanufactured cartridges. These tend to degrade print quality and printer/cartridge performance.
Please note that once a cartridge is refilled, it can no longer register its ink level.
Sep 13, 2011 | Lexmark X8350 All-In-One InkJet Printer
Had the cartridge filled instead of buying a new one. I was told at costco that the printer sometimes shows low ink when it's filled to check the manual there is an option that needs to be changed. I...
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed
Another thing which is mentioned at their support site is quote:
If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
If you find my answer helpful, please vote. Thank you!
Nov 16, 2010 | Lexmark X8350 All-In-One InkJet Printer
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
Problems with Lexmark X2550. I have refiled for the first time a lexmark 28 cartidge. Now I have paper jam all the time, I cannot print and I don`t know what to do. I blame the cartidge, because before...
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 03, 2009 | Lexmark X2550 All-In-One Printer
My Lexmark X2600 ran out of the black ink cartridge. I refilled the black ink cartridge but it refuses to recognize it and will not let me use it. Gives me an option to use the color one only or cancel. ...
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Jun 19, 2009 | Office Equipment & Supplies
I cannot get my printer to recognize my refilled ink cartridges
Apr 20, 2009 | Lexmark X2500 All-In-One Printer
I just refilled black ink of my new printer Lexmark x5495. Does not recognise the black cartilage and keeps on asking for alignment. When it prints alignment page it does not use the refilled black ink....
Apr 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x4530 won't print with refilled ink
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Feb 17, 2009 | Lexmark X8350 All-In-One InkJet Printer
Refilling lexmark cartridges x2500
Jun 03, 2008 | Lexmark X2500 All-In-One Printer
X8350 lexmark cartridge refill
Carefully lift the tape sticker and there are three very small holes under, with a thin screw make them a little bigger and test with a pin the corresponding color and then inject 4 to 5 ml. of ink in each one, after that reapply the tape sticker.
Apr 25, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X8350 All-In-One InkJet Printer Logo
146 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
