Good day to mam wendy311!!!!
If you TV is totally dead set and no red light or green light on the front...
if that so the problem could be cause of dead set power power supply board...
You have 3 choices its either repair it on your own or took it to the technician or buy a new set of power supply board..
But for me I suggest to buy a new power supply board because if you took it to the technician cost of repair is almost or higher depends on the bad parts than the new power supply board...
But before you buy a new PSU please check this simple and common parts that usually cause of dead power supply board..
- Transistor----Check if shorted
- Capacitors----Check if bulged or leak.
- Resistors----Check if open or change value..
- Fuses---------Check if busted..
I hope this solution will be helpful..
Thanks for using fixya...
