posted by L_ask on Apr 29, 2008
Thr LCD projector was powered down after use,
the light was off and the fan was still working.
Somebody accidentally pulled the power cord and the unit
was disconnected from power - and died.
I assume the shock could damage the lamp but ..
now no any LEDs are on, including the one that indicates Lamp/cover problem.
Connection of the power cord makes a typical capacitor charge
("static" noise) sound , all internal fuses are fine but the power
supply does not turn on, it seems like the PS died but it hard to
believe it did not survive the power surge.
Do you thing replacing lamp can make any sense?
Did anyone met similar problem?
Solution #1
posted on Apr 30, 2008
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sony LMP-C121 Projector Lamp for
Email this problem
Email this problem
Can you Help with these Multimedia Projector Replacement Lamps problems?
Continuity test for a projector...
Can I use an ohm meter to test... Answer This...
invert image on projector
i have a generic chinese... Answer This...
magnavox replacement remote...
a some where to purchase one in... Answer This...
image is flickering
image is flickering
The ?flickering? of the... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
