Question about Cameras
When I plug the USB going from my laptop to my Rebel, the camera flashes the word "busy" continuosly and my laptop cannot find the image info.
  • Mike Johnson
    Mike Johnson May 11, 2010
    have you tried removing your len while connecting it ??? or fise vers.
When I hook my e300 to the computer it won’t show on the desktop. The cameras on but it’s stuck on “one moment please. All 8 of my other digitals from Olympus work fine. What’s going on here? It’s all turned on but it won’t show up. Thank you.
Alsphotography@earthlink.net
Posted on Apr 30, 2008
Canon rebel T1i won't take a photo and gives message busy
Try formatting your card in your computer and then in the camera. If problem persists then try another memory card. You need to determine if it is a card or a camera problem
May 12, 2014 | Canon Cameras
Canon Rebel flashed busy and now after changing battery, it won't do anything except display date page.
The bottom right screw on the rear board on this model comes out and shorts out parts of the circuit board. This may be the cause of your camera's problem. It is always this screw and it happens to about 50 % of the cameras I see.
Finding and replacing the screw may solve the problem, but it sounds like the screw may have done permanent damage to the rear board.
Feb 04, 2013 | Canon Rebel XT / EOS 350D Digital Camera
My name is Madhu. I use the camera Canon EOS 400D / Digital Rebel XTi. When the inbuilt FLASH is on then a message pop up as "busy now", when i tried to click the camera to take a photo then...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you
Apr 04, 2011 | Canon Rebel XTi / EOS 400D (body only)...
I have a Canon EOS 350D, Compact Flash card freezes my computer
Instead of connecting via the camera, just use a USB card reader and put the CF card in that.
Mar 17, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Busy signal when trying to import images to my pc
I have had the same problem with getting a busy signal after plugging in the USB cord. Usually turning it on and off a few times, giving it a few seconds in between, works for me.
Also, have you tried just going into My Computer and clicking on the drive for the USB you've got you're camera plugged into and transferring the photos onto your pc from there? They only go onto your pc, not into a program but you can get them into one from there.
Dec 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Transferring images to my pc
Sounds normal. You could get a faster computer. I like using a  USB card reader.
Sep 18, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Connecting my Rebel to my Laptop
I would highly recommend you to use a fast USB 2.0 compliant Compact Flash card reader to copy photos from your CF card to your PC. This is much faster than trying to copy the files from the camera, as your camera is USB 1.1 compliant (ie. very very slow).
However, if you wish to use your camera to copy files with Windows Vista, you must switch your 300D to operate in PTP (picture transfer protocol) mode instead of Normal one. (in the camera's screen, go to the last tab, and change the option: Communication from Normal to PTP). I am not sure though that the PTP mode will allow you to copy RAW images. You have to check it.
As for the RAW images, I suggest you download and install the Canon RAW codec from:
http://software.canon-europe.com/software/0026049.asp
This codec will allow you to open CRW files directly from the Windows Photo Gallery application. Perhaps if you install this codec first and then try to connect your camera in PTP mode with your PC, to succeed in what you want. Still though, I recommend you to buy a cheap USB 2.0 CF card reader, it will save you hundreds of hours of Camera to PC download time.
Hope this helps.
Jun 22, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel XT / EOS
In the communications option of the camera Menu, there are two options to choose from. Try changing the options. one of them works with Canon software to download images.
Dec 10, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
228 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
