My Coolsat 5000 won't power up. It has dim red light(s) on the front when turned on, but that's it.
  • 2,323 Answers
This failure can be located in the power supply. Open the receiver and look for part C21 and replace it. That should fix you receiver.
Using a de-soldering iron or de-solder ****** remove C21 (1000uF/6.3 volts).
Replace C21 using the same capacitance of 1000uF/6.3 volts or a higher voltage is acceptable if the part does not interfere with the adjacent capacitors. 1000Uf/35 volts should fit in there as well.
Good Luck.
Posted on Apr 29, 2008
Lighting ran in on my lg47lg50 tv now the red power light is on but the tv wont come on
The power board is cooked. consider another tv.. Consider using surge protection in future.
Apr 01, 2013 | Televison & Video
LG 32LC56-2C will not turn on, red light establishes after a while but won't turn green
This model was known for capacitors on the 12 volt line giving issues, if your able to change them this should fix it for you, you can buy them online for about a quarter each
Nov 28, 2017 | LG Televison & Video
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
I have a 1998 Champion 181 bass boat. The navigation lights are not working properly. - When I plug in the front green/red light, it immediately comes on with control switches in the OFF position. (The...
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
Apr 15, 2009 | RTO Oar Sockets
Coolsat 5000 platinum remote codes
Press ok and device and then enter code to do manual search push ok device at the same time light will blink twice then keep pushing up on the channel button until tv shuts off then push ok then you are done i hope this helps.
Feb 27, 2009 | Jensen 143307 Remote Control
I have coolsat 7100 reciever. On the front of the box panel it wouldn't let me go up or down or turn power off.
It sounds like you got a bad flash. Try to re-flash it with factory firmware 3 times, then reload your current firmware and see if the problem is fixed.
Feb 01, 2009 | Computers & Internet
Coolsat 6000 fta connection
if your hooking it up just to ur TV you would need The RCA Video Cable, Video- yellow, Red - right, white is left,Witch is printed on the back of the box, this would go into the output an go in to TV input
Hope it works
Oct 17, 2008 | Toshiba SD-H400
Red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Feb 14, 2008 | Compaq Presario 5000 PC Desktop
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Electro Med Services...
