Noise from onkyo 505e
When I power on the Onkyo 505E from standby there is a buzzing noise that comes from the receiver. Please tell me how to stop this as it is very annoying.
    Scholar:
  • 154 Answers
You can try to turn the stecker around some times this helps as some equipment is sensative to plus plus instead of plus > min connections
Posted on Apr 29, 2008
I have a Westinghouse 505E dryer and it won't
if its making a buzzing sound the motor is stuck its proberly full of lint it need taken apart and vac out around the motor / or it could be motor bearings worn or the belt brocken you will need to take apart to hav a look
Dec 09, 2011 | Dryers
I have Onkyo HT510 receiver. does not turn "ON".
hi,
There is a standby transformer inside the Onkyo receiver at the mains input stage. If the standby transformer is faulty then the unit will not power on. There will be two transformers. One is big and the other is a small one. The small tarnsformer is the standby transformer. Which will be fitted on a small board where the power cable is connected. Replace the transformer to rectify this problem.
OK
Oct 15, 2011 | Onkyo HT510 Receiver
Hello. I have Onkyo tx-sr606 home theater
could be a bad soldered joint or loose connector, even a bad earth in the secondary power circuit.
Feb 27, 2010 | Onkyo TX-SR606 Receiver
Is there an incompatibility between Onkyo 606 and KEF Wireless?
This is cycle hum place offending units away from each other or, isolate the power supplies and, re- check electrical circuit grounds
Jun 01, 2009 | Onkyo TX-SR606 Receiver
Sorry this is not a solution.
I am having virtually the same problem and I wanted to find out if you managed to fix the issue?
It seems to be my LCD causing the static noise (even when it is powered down). The static noise goes away when I physically unplug the TV or disconnect the HDMI cable to the amp.
Mark
Mar 23, 2009 | Onkyo TX-SR606 Receiver
A couple of weeks after initial setup of my brand new Onkyo XT-SR606 receiver, I noticed a loud buzzing noise that starts up approximately 10 min after the receiver is turned on. The buzzing is definitely...
The "buzz" you hear is a power hum made by the power supply transformer. It's technically called "Lamination hum" caused by the revering of electrical current through the power supply transformer. In some cases the hum can vibrate the chassis causing other loose material to vibrate. If you can, go to your dealer and check to see if other units of this same type typically make a hum this loud, and if not, see if he can solve the problem for you.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
"standby" on Onkyo TX-910
That sounds like an internal problem inside the unit
Jul 18, 2017 | Onkyo TX-910 Receiver
Questions about Onkyo SR505
1, remote codes, check with sayno for code updates. Or consider a harmony remove last remote you will every buy.
2. Receiver does not convert video standards, need svideo cable.
3. popcorn hour player, no idea what that is , but like number 2. will need a seperate hdmi cable.
However, if the receiver and the player both have component, i would not hesitate to wore everything up component. In your application component video is better than hdmi. To many reasons to list. Good luck
Jun 10, 2008 | Onkyo TX-SR505 Receiver
Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Nov 15, 2007 | Onkyo TX-8522 Receiver
106 people viewed this question
 Grubhead
Grubhead
