Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-28FD1E Powers up and than go in Secure,and nothing more.
  • Bronco5 May 26, 2008
    Sorry,this is noth the problem i askt for.
    The problem with my Sony KV-28FD1E Tv is,that the set switced on, i have sound but noth video picture.I can switch over too text mode and it works,even the osd indicates.If i connect a PC to the PC input then i have normal video coming from the PC.
    But if i connect to the Scart 1,2 or 3 or else ther is now video only sound.
    Too tel it in short evething is working fine but i have no video,only from the pc input.
  • 1,512 Answers
Hi Bronco5
The set is shutting down into protection mode because it has a problem that will need to be repaired. It is likely that a power supply has a fault, or an associated power section of the set has developed a fault problem. Because of the complex nature of Sony power supplies and isolating the fault, If you are not an experienced electronics technician familiar with these circuits, I suggest taking it to an authorised Sony service center to get a quote on repair. Sorry this is not perhaps the solution that you were hoping for, but is the best advice in this case. Feel free to ask any questions you may have, and I will try to answer them for you. Good Luck
regards
robotek
Posted on May 24, 2008
    President:
  • 2,712 Answers
Seems to be a problem with the power board. Most likely a failing flyback autotransformer. You will most likely need to replace this part.
It is best to call a TV technician for this kind of job, especially if you are not experienced in this. There are voltages inside that can kill.
However, if you think you can manage a DIY, please try THIS site. They have spares and provide online chat assistance and you will have unlimited professional support so you can diagnose and repair your television yourself.
Should you have any further queries, please post back and I will be more than happy to assist you further.
Hope that helps, and good luck!
  • Swilin Sampson
    Swilin Sampson May 26, 2008
    Try changing the Scart cable. It seems that may be defective. If that does not work, it could be that the Scart jack on your TV may have some bent pins. Try using a needle nose pliers to gently bend the bent pins back in shape.
    You can also try cleaning the contacts with a bit of cotton dabbed in isoporpyl alcohol.
    If you are still having issues, you will most likely have to get the Scart jacks replaced. Or you can try connecting the cables using the RCA connectors.
  • Sony Master
  • 19,396 Answers
If it goes in secure mode immedately after power up then it is probably a problem with the power unit, in need of replacement.
If the power led is blinking a certain number of times it can be also a problem with control board.
Tell us if you have led blinking or any additional symptom.
    Genius:
  • 3,422 Answers
Can you tell me the no of blinks you can see?
Posted on May 17, 2008
Sony trinitron kv-32fs10 component color problem
check the av in puts of your tv, this sounds that your av jack has a loose joint on the connection under.
May 24, 2010 | Sony KV-32FS10 32" TV
Our Trinitron KV-36XBR400 powers up then no picture
How old is this tv?More than 5 years old.Not worth it to repair CRT tv at this prices.Tries unplug,replug an hour later,might help,see if reset itself.U can buy a pretty good 32" LCD tv at $400 or less these day.It not heavy as the CRT tv,it alot easier to move the tv around the house or other locations.
Feb 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kv-32fs13 chirps and flashes
Hello 0279737,
This problem is caused by a shorted Horizontal Output Transistor. I would suggest that you have this TV checked by a qualified TV technician. This type of problem requires dealing with dangerous voltages, and repair should only be attempted by a trained technician.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Oct 28, 2008 | Sony KV-32FS13 TV
Sony kv-32fs100 won't power up
Problem inside the tv, maybe leak parts inside you need repairman tech.
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Wega KV-27FS120
This may be a power supply, and or a high voltage, or a scan ampplifier failure. The set would have to be properly trouble shooted by an experienced TV tech to determine the exact failure. This is not something you can fix yourself at home.
Jerry G.
Apr 15, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SONY Trinitron TV doesnt turn on
TWO Blinks
B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Nov 09, 2017 | Sony KV-27V40 27" TV
Sony KV-32HRS10
I need more info. Sound ok but no picture? Do you have displays? (Vol bar, chan #, etc).
Feb 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
