Question about E-Machines eMachines Desktop PC
E machines takes 10 min to open windows.
When I turn on my emachine computer there is a black screen with a silver emachines logo (e) on the screen. In the bottom right hand corner it says boot menu
Pack it up and thow it out
Posted on Apr 29, 2008
How do i change boot order on emachine t3604
You will need to change the boot order in the bios set-up.
Turn your computer off, and turn it n again (alternatively Restart it) These things may be initiated by clicking the Windows button at the bottom left of tour screen, and from the shut down drop down menu selecting the appropriate option) As your computer is starting up, and the Emachines logo appears on the screen
"Press the "Tab" key repetitatively: If that fails to take you into the BIOSsetup, repeat and try either the "Escape," "Delete," or "F2" keys instead of the Tab key.
Once in the BIOS setu[p, Look through the options until see Boot order, and then change that to CD first, HD 2nd. Exit the BIOS setup with save changes option. Done.
19.February.2015
Feb 19, 2015 | eMachines T3604 PC Desktop
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Emachines t1116
Usually e-machine and other pc's have a factory restore setting set up in case of an error. You can; according to emachine tap the "Alt" and "F10" keys at the same time when the eMachines logo appears. Press "Enter" and follow the directions on the screen to recover the operating system back to factory condition. I hope that helps, if those keys don't work try F11 at the emachine logo. Good luck.
Nov 17, 2011 | E-Machines eMachines Desktop PC
I have a problem with my computer emachines j4501 desktop pc windows vista home premium..after the windows logo the monitor turn blank...but the cpu is still on.... what will i do...
If you can see the windows logo screen both your computer and monitor is working, possible problem could be that the display settings are set to high that your monitor is unable to handle it. Restart computer and keep tapping F8 key. This will take you to the advanced options menu In the list of options here choose enable low resolution mode and hit enter (you can only use your keyboard to choose - use the up / down arrow key) once you enter windows low res mode change it to 800 X 600 and restart the computer Once you are in the right mode now change the display settings accordingly.
Mar 12, 2011 | E-Machines eMachines Desktop PC
I have a emachines T5274 with vista home Premium.... and when i turn in on the Emachines logo pops up BUT stay up for a long time around 1-2 mins and it use to be around 4 secs!! then it goes into the...
It sounds like you may be trying to load a lot of temp files.
Go to CNet.com download Advanced Systems Care "Free Edition"
Follow the directions to clean up your system.
If that does not fix the problem Download a copy of Glary Registry Repair (also free) and run that.
These are two of the best software packages to have.
I have been useing them both for a long time,and have tried others, but these two are far and away the best I have found- and they are free!
Oct 04, 2010 | eMachines T5274 Desktop PC
Emachine 786n mointor frozen emachine logo
Try a different monitor. Most likely your having operating system issues that cause the monitor to do this.
Also - try this - As you turn the machine on tap the DELETE key - this will take you to the DOS platform of the computer. If the screen changes to anything you have operating system issues. Try a repair with the original disk or the operating system disk that was last installed.
May 08, 2010 | Computers & Internet
All i get is a logo
open your cpu cabinet.
Then Refix RAM memory.
Pull cmos cell from motherbord chipset for 15 minutes then all motherbord bios settings are defaults.
Then check.
Jul 31, 2009 | E-Machines eMachines Desktop PC
Have T5026 emachine with boot problem
Sounds to me that theres a good chance that the windows files are corrupted. It is possable that its could be hardware, but software is free so start there.
If youve got the recovery disks then put them in and restart. Just attemp a repair of your windows. its worth a shot. you may need to go into your boot setting to boot from disks.
if you havnt got them and you havnt got warrenty them youll have to format the drive and install a fresh copy of windows, and find all the drivers from the emachines after.
1st get all the stuff off the drive that you need/want, take the drive out and connect it to another pc or use some sort of external connection.
then find a copy of windows that matches the licence sticker on the case of your pc. throw the hdd back in and boot the disk, format the drive and install windows.
youll have to get the drivers from
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T5026
Feb 04, 2009 | E-Machines Emachine T5026 power supply **...
E-Machines eMachines Desktop PC Logo
111 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
