Question about Vacuums
I have a bissell power steamer That is not spraying soap, only water. I have checked all the filters and belts that I know of I also tried to reprime the pump as indicated in the trouble shooting section. Is there anything else I can try? Thanks
  • 2 more comments
  • Anna Moeller Apr 29, 2008
    I also Have put clean water in the solution container, but nothing is coming out
    It does not turn all the way around, but stops where it is supposed to
  • Anna Moeller Apr 30, 2008
    where can I get a new cao and or insert?
  • wolverine95 May 05, 2009
    The machine is not dispensing soap. When turning the dial to 'water rinse' it dispenses water, but only if I turn it off and let the vacuum wind completely off, then turn it on again.
    If I turn the dial back to any of the 'soap' positions (light clean, normal clean, heavy traffic) it quickly loses pressure and then stops spraying anything at all, or sprays very little at all.
    It's as if there's a vacuum leak in the lines, or a pinched line, but I can't seem to find any problems, and the unit was never taken apart previously (i.e. how would the problem start in the first place).
    Any ideas? The pump, motor, belt, etc all seem to be fine.
    I've also tried blowing out the lines with my air compressor, and that hasn't made any difference.
    Thoughts/ideas?
    President:
  • 1,673 Answers
If it spraying water, then the pump is ok. The valve at the bottom of the soap bottle may be bad. Also when you turn the smart mix vavle, does it turn easily or hard, if hard, try spraying some furniture polish around the knob and turn it to work in in, if it turns all of the way around and doesn't stop where it is supposed to, then the knob or the top under the knob is broken.
Posted on Apr 29, 2008
  • Lauren Junge
    Lauren Junge Apr 30, 2008
    Sounds like you need to replace the cap and insert for the soap bottle which may come with the bottle.
  • Lauren Junge
    Try Bissell.com or a local repair shop should be able to get it for you.
Water line routing
The biggest prob with Bissel is not pumping soap. Becuase if you don't run hot water through this tank the soap will dry and clog after cleaning and storing. Before taking it apart try running hot water through the solution tank and help break up the residue, best of luck. Steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Won't spray wate rwhen you press trigger.
When the water won't dispense that usually means that the pump belt is usually stretched or broken. Here is a link to the belt you need and a manual you can view:
Bissell 7920 Belt and Manual
Dec 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Wont **** up water
Go to bissell.com go unger frq.asked questions. Also check your belt
Jul 23, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell proheat 7901-1 steamer won't **** up the water
Sounds like either the pump is not working or the collection unit has an air leak.
Apr 01, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Power Steamer Pro
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
My Bissell shampoo machine will not spray either water or soap
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yuet
Oct 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell power steamer - upright deep cleaner - Does not **** water
If this unit has an onboard heater ( a little red lite in the center of the handle) then most likley it is the problem. You see the heater which is located inside the large portion of the handle has a very small passage that snakes its way throught and heats the water as it passes. The problem is that the water and soap are mixed before the heater which is very very hot and when you turn the unit off and the solution stops moving and hardens in that little passage while the heater cools. To fix this you have to take the handle appart allong with the heater and clean it out. To prevent this in the future make sure to turn the heater off and run just clean water through the unit before you put it away. This unit also has a belt that runs the pump check to see if the belt is in good shape it could be stretched but not broken I would suggest replacing it anyway just to be sure. You can buy the belt allong with other parts for this machine at www.stevessewandvac.com
Aug 12, 2008 | Vacuums
No water or soap coming out
the filter could be block under the flow indicator cap,
but water should still come out of the hose
Nov 07, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
232 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
