Question about Dell 2200MP Multimedia Projector
Dell 2200mp mounting screw
Purchased a ceiling mount for a dell 2200mp projector. What size screw is used to attach projector to mount? The 3 threaded inserts seem awfully small.
  • 563 Answers
Hi wspy
If the look right next to the holes there should be a screw size written on the casing itself.
Posted on Apr 30, 2008
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
What size are the mounting screws?
The brass mounting holes on the bottom of Hitachi data projectors require a 4mm bolt.
Typicall 4mm x 10 is the shortest bolt I will use if when installing a projector on a ceiling mount, and 4mm x 20 will be the longest. I also recommend picking up 3 washers and spacers of varying sizes if you want to insure the projector is mounted level without warping whatever it is you are attaching it to.
BMS makes great locking mounts that come with all the mounting hardware you'd need to attach a projector to it.
Jan 03, 2010 | Hitachi CP-S240 Multimedia Projector
How to mount using a universal ceiling mount
first, find out the distance range on your projector for the best fitting image on your wall. next, what type of ceiling? if it's a drop ceiling, use a plate to span the 2 feet between braces and clamp it to them. and it's always safe to attach a safety cable from the mount to something sturdy, like wood or heavier metal. if you are putting it on a drywall ceiling, find a stud to screw it in to. do not use drywall anchors to hold it. if you can get above the drywall, use a backer board (2x4 or plywood, 1/2" or thicker) and screw the mount through the drywall into that. the other end of the mount screw into the bottom of the projector (3 or 4 m4 holes should be already on the bottom of the projector. use the screws provided. you'll have to adjust the mount so it matches the projector holes. once it's mounted, you'll have to adjust the image. go into the menu and select ceiling image, and adjust the keystone. pop in a movie and enjoy!
Dec 22, 2009 | Acer P3250 DLP Projector
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
How do I mount the HC1600 projector
there are three screw holes on the bottom of the projector, 2 in the back by the feet and one in the front. they take a standard size, I think it is a 6x4....
I had a infocus projector mounted to the ceiling and took it down this weekend and put the hc1600 in using the same screw and same adjustable ceiling mount.
Dec 24, 2008 | Mitsubishi HC1600 Projector
Black band
Hi PFCS
This is unfortuantely a well known sign of a faulty Mainboard.
And this will have to be repaired by an authorised service provider.
May 20, 2008 | Dell 2200MP Multimedia Projector
Hitachi CP-S225 projector - spec for screws
Hi Brian
The $18 footpiece you will unfortunatelly have to pay if you want the right thing.
As for the screws to mount the bracket onto the Projector , simply look right beside the hole at the bottom. Normally the size screws that you require is printed in the plastic.
Apr 15, 2008 | Office Equipment & Supplies
Hampton fan
You are probably missing a part. There should be a mounting plate...usually round...that attaches to the ceiling or electrical box. The mounting plate would have small tabs or a lip around the edge with threaded holes for attaching the cover.
Jan 16, 2008 | Dryers
Ceiling mounting
I unscrewed the two rubber stands on the bottom and used those to screw it to the ceiling mount. Seems to work pretty well!
HTH!
Dec 19, 2007 | Toshiba TDP-S8 Multimedia Projector
Dell 2200MP Multimedia Projector Logo
381 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
