I have a HP media Centre m487.uk desktop PC and when connecting a new samsung monitor with the DVI cable, get a blank screen. The analog signal works fine though. There must be a setting that needs to be changed perhaps? I just can't find anything that will work. I am using Windows XP
Most monitors with both analog and dvi have a switch to change. So on the monitor, look to see if you have a setting for which connector to use. it should be in one of the menus on the monitor osd
Posted on Apr 29, 2008
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
Can i get an adapter for my emachine monitor to go into a dell desktop ...my lead i have now doesnt fit as unable to screw it in
YES.
I believe it is time now for the guessing game............
1) Is the monitor about so high, and so wide?
2) Does the monitor look like a small TV, or is it flat in appearance?
3) What does the monitor cable look like?
4) Is your hair Brown, and do you smoke cigarettes?
NO.............just wanted to see if you were following along! Geez!
An Analog monitor, such as a CRT type of monitor, uses a VGA cable,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for a VGA Cable example.
Flat LCD screen monitors are Digital.
Some may have a VGA Cable attached, but the best cable option is a DVI cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
(Click on any photo on those two Wikipedia pages, to enlarge)
Using these two examples, does one apply to the eMachines, and one apply to the monitor?
Let us say the monitor has a DVI cable.
The eMachines Desktop PC has a VGA port. (Connector)
For this you would simply use a DVI to VGA adapter,
http://www.directron.com/dviadapter.html
Now notice...........this is a VGA MALE to DVI FEMALE.
The DVI cable on the flat LCD screen monitor, has a male connector.
The contact pins of it go into socket holes, in the DVI end, of the DVI to VGA adapter.
The VGA port on the eMachines, has socket holes.
The male VGA connector end on the DVI to VGA adapter, has contact pins.
Point?
Make sure you get the correct DVI to VGA adapter.
There is a male DVI to female VGA adapter, also.
This is just one example.
For instance I'm using an HP 2009M 20-inch widescreen monitor, AND an RCA 26-inch HDTV, as dual monitors.
Presently using the HP 2009M with a DVI cable, and the RCA L26HD31 HDTV with a VGA cable.
(I'm also using an ATI Radeon HD5450 graphics card. Pretty 'pud', but it does OK for what I want)
Primer;
A computer sends out a digital signal. To get the best graphics quality, you ideally use a monitor with a digital cable. (DVI, etc)
When you use an Analog monitor on a computer, the computer has to change the digital signal down to an Analog one.
Therefore the graphics quality is not as great.
Digital cable technology now, is DVI, HDMI, Display Port, and Mini-Display Port. And some others I'm sure I've forgotten.
http://www.hardwaresecrets.com/article/Video-Connectors-Tutorial/157
For additional questions please post in a Comment.
Also post what the monitor manufacturer name, and model number is. (Look on the back)
Are you using the VGA connector on the motherboard, (Back of computer), or do you have a graphics card installed?
If you have a graphics card installed, what is the manufacturer name, and model number?
Regards,
joecoolvette
Mar 06, 2013 | Dell Dimension 4300 PC Desktop
How can i use dvi port
DVI stands for (D)igital (V)ideo (I)nterface.
DVI is a new form of video interface technology made to maximize the quality of flat panel LCD monitors and high-end video graphics cards. It is a replacement for the P&D Plug & Display standard.
you can connect high definition monitor , LCD projector , LCD T.V to a DVI port
There three kind of DVI connector
1. DVI-D (Digital)
2. DVI-A (Analog)
3. DVI-I (Integrated Digital/Analog)
DVI-D format is used for direct digital connections between source video (namely, video cards) and digital LCD (or rare CRD) monitors
DVI-A - High-Res Analog
DVI-A format is used to carry a DVI signal to an analog display, such as a CRD monitor or and HDTV
DVI-I - The Best of Both Worlds
DVI-I format is an integrated cable which is capable of transmitting either a digital-to-digital signal or an analog-to-analog signal, but it will not work transmitting a digital-to-analog or analog-to-digital signal.
How to Recognize These three types of DVI Cable
There are two variables in every DVI connector cable, and each represents one characteristic.
The flat pin on one side denotes whether the cable is digital or analog:
A flat pin with four surrounding pins is either DVI-I or DVI-A
A flat pin alone denotes DVI-D
The pinsets vary depending on whether or not the cable is single- or dual-link:
A solid 27-pin set (rows of 8) for a dual- link cable
Two separated 9-pin sets (rows of 6) for a single-link cable
Jul 12, 2011 | Computers & Internet
DVI won't work
WOW! I have that monitor too on one of my systems!
Strange thing is it HATES the SVGA connection ~ but works FINE with the DVI... wish I could tell you why?
I've tried a array of 'new drivers' but none help... STRANGE thing too is OTHER monitors work FINE (with the VGA port) so I'm fairly confident it's not that...
I CAREFULLY inspected the pins on the male connectors to assure none are pushed back into the connector body and tried new cables too... still NO GO?
PLEASE let US know if you found a solution!
Anthony
Dec 12, 2017 | Samsung SyncMaster 214T Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Feb 13, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Analog output works fine, but no signal for digital output
is ther option on screen it self dvi mode and anlog mode .
Jan 24, 2008 | Sun - XVR-100 Graphic Card
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
