Question about Refrigerators
Frigidaire frige not getting cold but freezer working
My refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. any help is appreciated. thanks. frigidaire mrs22wngw0
  • Ritzzy May 12, 2008
    My refrigerator is not getting cold but the freezer is working fine.
    Frigidaire FRT21HS6JM
  • Anonymous Apr 20, 2009
    same problem!
    the freezer is working but not the fridge!
My refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Posted on Apr 29, 2008
  • 38 Answers
When your freezer is working ok it's all about the air flow into the fridg.check all vents and dampers
Posted on Dec 22, 2011
My freezer works but the refridgerator doesn't get very cold
If freezer works airflow into reefer box from the freezer box is too low, ironically enough although the thermostat saying 1-10 and OFF, controls the temperature/compressor operation setpoints desired, but the second setting saying COLDER/WARMER, when set to COLDER actually makes the freezer box colder by starving the reefer box!!! if you back of that settting to middle the reefer will get air again, A very common issue , caused by this wording, it says COLDER freeezer if you really look most just peg both and say hey the reefers warm and freezers cold??and both are set max cold, or so it seems!
Nov 01, 2010 | Frigidaire Refrigerators
Frigidaire top/bottom fridge is on, but not cold in either the fridge or freezer.
We bought a small used Frigidaire refrigerator-freezer on top--Freezer is cold but items in frige are not...what could cause this
Feb 09, 2010 | Frigidaire Refrigerators
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Feb 07, 2009 | Frigidaire FRT15G4B Top Freezer...
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Fridge not cold, freezer fine...
look at the back inside wall of the freezer. you might need to put your hand on it to feel it. if you see or feel frost the you have a defrost problem. if its not defrosting the frost builds up and blocks air flow from the freezer to the frige so the frige cant cool. it will either be the defrost element, defrost thermostat or the defrost timer causing the problem
Nov 25, 2007 | Kenmore 71279 Bottom Freezer Refrigerator
Refrigerators Logo
985 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
