Question about GE WSXH208A Front Load Washer
Changing the water inlet valve
Please let me know where the water inlet valve is and how to change it. (Do I need to go through the back or top or front bottom of the machine to change it?)
    Genius:
  • 1,073 Answers
Remove the top, the water lines from the house connect to the water inlet valve, you can see it near the top with the top off
Posted on Apr 29, 2008
Push button , locks machine but no water fills
check your cold inlet water solenoid valve , remove blue hose and check you have water to machine if ok check you have power to valve if you have power and water and still no water going into machine then its your valve that needs changing ,
Jul 09, 2014 | Maytag Centennial Top Load Washer
Maytag regrigerator MSD2651KES
Changing the 67006531 Water Inlet Valve is quite simple. If after
watching this short video you have questions please let me know If you want a service manual for this model let me know HERE. I can't post the manuals for everyone to copy. Thanks Sea Breeze
Video Here=> Refrigerator Repair - Replacing the Water Inlet Valve (Whirlpool Part# 4389177)
Nov 24, 2012 | Refrigerators
The ice is no longer coming out cubed - just a big clumped together mess on my Samsung Bottom Freezer's internal ice cube maker
Hi and welcome to FixYa, I am Kelly.
This symptom is caused by a water inlet valve that is bypassing water when it is supposed to be shut off. The inlet water valve is not repairable and must be replaced when this symptom occurs. There can be yet other problems with he ice-maker itself, but changing the water inlet valve will correct this about 95 % of the time. Changing the inlet water valve is the first step in troubleshooting. Should you call for in home service; the tech will change the inlet water valve before doing any other troubleshooting and will most likely have to return after 24 hours to continue ice-maker troubleshooting.
If you need help locating a replacement inlet water valve I will need your complete model number.
Thanks for choosing FixYa,
Kelly
Mar 16, 2011 | Samsung Refrigerators
The water wont' shut off...have to shut off at the faucet valves
Water inlet valve is not closing//Replace water inlet valve...If I helped you please vote need to know more please ask///good luck
Feb 04, 2011 | Maytag Atlantis MAV6000 Top Load Washer
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Water leaking into tub when washer is not in use
Hello, Yes it is the valve leaking, remove 2 screws at the back top of the washer, slide top panel backward and lift, once you have removed the top panel you should see the valve, they are fairly easy to replace. Good luck!! Mike
Aug 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water doesnt work
Hi, First check and see if there is something plugging the cold water inlet screen. Remove the cold water hose to look at the screen. Another way to test the inlet valve is set the washer to cold wash, listen for the inlet valve to buzz or hold feel the cold inlet fitting and see is you can feel it vibrating.
If there is nothing plugging the inlet screen and the inlet valve doesn't buzz, you will need to change it.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 14, 2009 | Kenmore 24032\24036 Top Load Washer
Ice cube tray isn`t filling with water but I have water on the door dispenser.
Hi, Check the inlet tube that comes through the back wall into the ice maker. See it has froze shut.
If there is ice in the tube, thaw it out and let the ice maker cycle. Plan on changing the inlet valve if the tube is plugged.
If the inlet is not plugged, let the ice maker cycle and listen for or test the valve for 120V. If there is a buzzing sound or you are getting voltage and no water, remove the tube frrom the valve that leads to the ice maker and see if water comes out of the valve.
If no water comes out of the valve, change it.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Freezers
Replacing water inlet valve
First of all, UNPLUG the washer before attempting any repairs, and follow these steps:
1. You will need to remove the washer top panel by loosening the three screws in the back. With the screws removed, the panel slides back, then off.
2. Turn off the water supply valves and disconnect the water inlet hoses.
3. The inlet valve should be very simple to replace at this point. Disconnect the electrical connections and the hose(s) leading from the valve to the dispenser.
4. There should be a a mounting screw holding the inlet valve to the back panel. Remove the old inlet valve and install the new valve in the reverse order of the steps I just provided.
This is should be a fairly straight forward repair that anyone can accomplish without the assistance of a repairman. If you get confused along the way, please post back and let me know. i hope this answers your questions.
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
225 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
