I own a Samsung CLP-500 color laser printer that consistently stops after 2 pages of printing with the orange light on and the message that the toner waste bin is full (which it is not) or the door is not closed (it is). Each time I must turn off the printe and wait about 1/2 hour or it to cool down before I can try to print a couple of pages again.
  • dufffixya Apr 29, 2008
    I purchased it through a small shop. How do I go about getting the manufacturer to replace it?
    President:
  • 2,712 Answers
Hello dufffixya,
1. This is most likely because the sensor for the waste toner tank is dirty or defective. The toner sensor is on the right as you look at the panel just below the liquid crystal display. There is a bump in the clear plastic just below the circular right vent port, that's where the used toner pours in. When you clean out the toner cartridge there is some residue left that makes the sensor think it's still full. Take a piece of paper towel and a small screwdriver (I'm told a bent coat hanger will work, too) and clean the inside of the sensor window inside the used toner cartridge (w/ access through the toner port). It looks like a little raised groove on the right. Just wipe it until it's clear on the inside. The sensor can now see through the window and you should be okay.
2. On the machine there is a sensor that looks trough the waste tank. Even though you have wiped it clean, it is likly that the sensor cannot see through the plastic waste tank.
I suggest vacuum the waste tank out until all the toner has gone then install it. If you cannot get rid of all the toner then wash the tank out and leave to dry then install it.
3. You can try taking a knife and take away the part which the sensor uses when reading if it is full or not. Of course, the flip side is that you will then have to manually inspect the tray regularly and clean/replace it when full.
As for the "Open Door" error, the order in which you open and close two of the covers is important, as there is an interlock between two of them. This can (and does) get damaged.
The toner access door is the first one you open, THEN the top cover (the one that gives access to the Transfer Belt and Drum.
Make sure the Drum unit is properly pushed into the printer, and that the Transfer Belt is located properly AND the two locking levers for the Transfer Belt are in their locked positions PROPERLY.
THEN close top cover - you shouldn't need to force it.
Followed by the Toner access door.
Yes check the duplex door too !
If this fails it is likely to be a broken case part, or failed sensor.
If all else fails, you may have to call in a qualified technician to check it out. If it is still under warranty, then it is best to get it replaced.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 29, 2008
  • Swilin Sampson
    Swilin Sampson May 01, 2008
    If it is under warranty, take it back to the store and get them to contact the manufacturer for a replacement.
    If the solutions I provided led you to a fix, kindly close this ticket by assigning a Fixya! rating to my solution
    Thank you in advance,
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • 62 Answers
It dose sound like a Manufacturing error. The following link is to the Samsung service location website so you can find a service location near you.
http://www.samsung.com/us/support/repairlocation/ServiceLocationsMain.do
This next link is to the Samsung service policy & warranty information.
http://www.samsung.com/us/support/repairpolicy/servicePolicyWarrantyMain.do
I hope these two links help you along the road to getting your printer replaced or fixed.
Also, you can always go back to the little shop where you purchased the printer and there is a chance they will trade you out for a new one and they will deal with the return of the defective unit.
    Genius:
  • 3,422 Answers
HI,
If the printer is under warranty just get it replaced from whom you purchased..
Goodluck..
  • Priya darshan Apr 29, 2008
    Please don't forget to rate the solution
    Genius:
  • 1,665 Answers
    Genius:
  • 3,587 Answers
Duff..only way to do this is if it's under warranty. Did you purchase it with a typical 90 or one year warranty extension?
  • Patrick Michaels
    Patrick Michaels Apr 29, 2008
    that issue about cooling down, sounds like a thermal issue, from the print engine , itself. If that's a new unit, this is a serious issue, and will result in unsatisfactory performance
  • 655 Answers
It sounds manufacturing error, you should ask for a replace as its new.
  • Iqbal Husain
    Iqbal Husain Apr 29, 2008
    you can find the distributor of the company in your city or your shopkeeper can help you.
  • Iqbal Husain
    you can easily locate distributor near to you by the samsung site http://www.samsung.com
Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
My samsung 315 clp has status LED red light on.
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
Dec 14, 2009 | Samsung CLP 315 Laser Printer
Clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Nov 14, 2009 | Samsung CLP-500 Laser Printer
Toner exhaust yellow toner
samsung clp color leserjet printer writes this massage toner exhaust yellow toner. i have done the toner refil without the reset chips about two times now and i have been printing for some time now i get the message "toner exhaust yellow toner"
Oct 01, 2009 | Samsung CLP 315 Laser Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
Different looking text, but only in certain areas of the page.
Samsung CLP-300 color laser leaves 3-4 lines of various shades of black in middle of paper. Otherwise everything is great.
Posssible black toner cartridge problem?
Jan 30, 2008 | Samsung CLP 300 Laser Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Faded Laser Printer
LASER UNIT NEEDS TO BE CLEANED IN CASE THE TOP GLASS THE SAME ASSEMBLY IS CLEAN HAPPY FAXING OMNIPRESENT
Sep 15, 2007 | Samsung CLP-500 Laser Printer
71 people viewed this question
jasbo
jasbo
