Question about Admiral AW22 Top Load Washer
Spin problems My machine is less than four years old and when it reaches the spin cycle it can bounce around the room, the drum bangs against the side of the cabinet. The only way I can get it to work is to remove everything and then little by little add it all back. I have been told there is a balance plate or something on the bottom of the machine and this needs replacing but I don't know where to look for it. I live in UK
    Genius:
  • 1,073 Answers
This is the snubber ring it is under the transmission it means a total disassembly to replace
Posted on Apr 30, 2008
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Hotpoint wf240 - jumps around when spinning laundry - the problem seems to be the drum turns too fast before the spin so the laundry is balled up before the spin - has anyone any ideas on how to fix...
Ensure that your machine is on a level surface with equal weight on the four legs. There are adjustable feet on these machines so as to balance the load on each support. These supports are adjustable by twisting them clockwise/anti-clockwise to get the correct balance.
Jan 05, 2011 | Hotpoint Washing Machines
The washer is 2.5 years old. The Basket has no stability during the spin and wash cycle. The basket bangs against the side of the machine and the machine bounces around the laundry room moving sometimes...
they do dance well dont they? this is caused by the support springs coming off the drum holder and the drum will have droped a little as well,
take off the top of the washer and look down each side you should see the support springs if the off just hook them back on or fit new one's?
dont leave this as it will pull all the pipes off inside the washer
its an easy fix,
Aug 09, 2010 | GE Energy Star WCVH6260F Front Load Washer
Excessive vibrating and banging in the spin cycle with some washes. The unit is only 1 month old. Any advice?
You have a improper installation. The machine has to be perfectly level side to side and frotnt to back. After leveling, check the feet on the bottom and see if one is bouncing on spin with a load. Adjust the bouncing foot down until machine stops bouncing.
Jan 25, 2010 | GE Profile WPRE6100G Top Load Washer
Spin Cycle - washer starts bouncing around room even though level
There are about 6 pairs of springs to hold the bottom tube to the bottom chassis. If some of these came off from designed positions, the tube won't be in balance then the washer starts bouncing off. Make sure these pairs of springs in place then you have no problem.
Sep 15, 2009 | Washing Machines
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Maytag Pav2300 top loader balance problem
bigmur, you need the snubber kit for this washer. There was a service flash out on this model, SF-26-756. The kit includes the snubber and 6 new springs. Condition was, excessive vibration during spin, basket leans to one side. Kit number, 12002357. Check with your retailer...this repair may be covered. Catriver..post back
Sep 25, 2006 | Maytag PAV2300 Top Load Washer
Admiral AW22 Top Load Washer Logo
109 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
