Question about HP DeskJet 3820 InkJet Printer
Printer startups After I turn on my printer it starts its inital cleaning of the cartridge heads. As it goes through this process there is a louder than normal clicking sound. When it is finished the printer won't print and the paper jam and on LED flash. I checked for a paper jam and there wasn't one. I took off the top cover and ran it again and noticed the cartridges are not moving across the print bar. I check for obstruction but found none. I did notice that what appears to be the head cleaning mechanism on the printer every time it goes through start up is jamming but I can't figure out how. Should I just get a new printer?
Yeah, I junked it and bought a new one thanks for nothing!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Apr 30, 2008
Unable to init. 50, Unable to Init 30,
paper jam or some sensor problem, in error 30, clean the strip encoder located at the top of the printer head, his color is transparent.
Jan 04, 2014 | Brother MFC-665CW All-In-One InkJet...
Tip
How to clean a Clogged/Blocked Print Head/Cartridge..
If you fault is according to user manual, a defective Print Head/Cartridge... The Print Head/Cartridge., maybe so clogged, and clogged up so deep that can not be cleaned in the normal way. Then, the printer can not communicate with the computer at this point. So you can't send the cleaning command to printer.
Here's what to do:
1. remove all the Print Head(s)/Cartridge(s).
2. Take out the Print Head/Cartridge. by releasing the lock lever. Look in the "Easy Setup Instruction" Step to find the location. Obtain a manual. (You can download it from manufacturers web site)
3. Put the Print Head/Cartridge. in a plastic zip lock bag. (Test the bag is air tight.)
4. Soak the covered Print Head/Cartridge. in hot water (hottest setting of the tap) for 5 minutes. The high temperature will soften up the clogged ink.
5. Immediately install thePrint Head/Cartridge. (Must be be dry) in the printer, and install all the ink cartridges.
6. Turn on the printer. If this works, you should not have a working printer, Now then, Most Important. Start the cleaning process from the computer. Run the cleaning several times to deep clean it.
on Aug 25, 2010 | Office Equipment & Supplies
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Hi pse help. My Canon MP600 printer does not print the magenta colour. I have changed cartdirges and tried evrything I could think of.
If you have already tried inserting a new Magenta cartridge & have checked to make sure that the piece of tape that covers the bottom of the ink cartridge has already been removed - then trying cleaning your print heads & aligning the printer.
You can access the cleaning features on your printer by pressing the menu key and using the up and down arrow keys on your keyboard to scroll the options until you see the maintenance catagory - then click on it. Continue scrolling the options with the arrow keys until you see the clean the print heads or print nozzles choice, then click on or accept to start the process. follow the prompts on the printer and try cleaning at least twice, then try a test page. If this does not solve the issue, then go back to the menu key and return to the maintenance area and choose align print heads instead. Press ok or accept to start the alignment process and follow the prompts on the printer until its completed. Check the print out to see if the color has printed. If it has not printed then you might want to try cleaning the print head area in the printer yourself.
To clean the print head area yourself, open the printer to bring the ink cartridges front and center to make sure they are accessible to you. Then turn the printer off and unplug it from the wall. Press and hold the power button for 45 to 60 seconds. Then open the printer so you can see the ink cartridges and remove them all. The print heads are located right below the area where the ink cartridges are installed. There should be a plastic tab to press or pull right under the ink cartridge carrier to access the print heads. Print heads look like plastic square containers with sponge heads on top. Remove each print head one by one and use a dry lint free cloth to clean up and ink spill you see there. Use warm water to clean the brass connections on the print head and in the machine to remove any dried ink. You can also use Qtips and alcohol mixed with water to remove any stubborn or stuck ink. When finished press the sponge to make sure its wet and not hard and dried out. Then reinsert them, plug the machine back in and turn it on. Try a test page or the alignment process one more time to see if you issue is solved.
If all of the above does not solve your issue, I suggest contacting Canon for assistance.
Sep 14, 2011 | Canon PIXMA MP600 all-In-One InkJet...
I did the maintanence cleaning and print test and it still prints out lines in the pictures
It might be running out of ink.
If cartridges are new then inkjet's heads are clogged. You can do the following to unclogged the heads, which might be located where the cartridges are plug into or on the cartridges itself.
Run 5-8 times the cleaning process from software. If doesn't solve.
Locate the heads an apply 5-7 drops of alcohol into heads and start cleaning process with installed cartridges again.
If the printhead is in the cartridge you can soak with hot water and also used alcohol drops.
Always run the self cleaning software utility.
Then try with new cartridge.
God Bless You!
Feb 05, 2011 | Brother MFC 420CN All-In-One InkJet...
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
My printer is only printing the clor blue for a
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have good ink cartridges properly installed? The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly. To eliminate this possibility, buy a new set of compatible cartridges on E-Bay - they're very cheap. You can always re-use the old ones later if it turns out they DO have ink in them.
If none of the above works, then you may have blocked print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process until you get a full black nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Apr 06, 2009 | Epson Stylus C84 InkJet Printer
C86 Goes through printing process but nothing prints.
Have you carried out 2 or 3 head cleaning cycles? If not, do it. Is there ink on paper now after this cleaning? If so, but it is streaky, leave the printer for 24 hours and repeat the head cleaning. If not, you must soak the heads for at least 24 hours - use print head cleaning fluid or distilled water NOT TAP WATER. Proceed as follows:
Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move by hand. Move it out of the way to the left. On the right you should see the print head parking area. There is a rubber cup that is designed to fit under the print head to keep the ink from drying out. Using a syringe or dropper, fill this cup with print head cleaning fluid. Then gently move the print head as far as it will go to the right. The print nozzles are now bathed in print head cleaner. Leave it for at least 24 hours, then repeat the cleaning cycle process.
Jan 28, 2009 | Epson Stylus C86 InkJet Printer
My black ink in my PIXMA MP760 printer will not print. I have gone throuh the maintenance process for cleaning and deep cleaning the heads and it still will not print any black whether it is text or...
The print Head has gone bad. Not using a printer that often will dry out the print head. The print head is where the ink goes. Try to get a cue tip and put some Alcohol in the place where the ink goes through. These should be small sponge like things underneath the ink cartridges.
Jun 06, 2008 | Office Equipment & Supplies
Ink and paper lights flashing red and I cannot print
No body wants to take it to repairs, we all hate spending money if it can be avoideded. Do't fret. First, i would bet you have a paper jam that you have missed. This would stop the carriage and head cleaning. Open up the cover as if replacing ink. Get a torch and really thoroughly check for tiny paper jams or ujo's(unidentified jamming objects)check where paper goes too. Now close cover turn off, unplug, all cables, replug, turn on, try printing now. Post back if no good. Cheers lilacgerry
Aug 27, 2007 | Epson Stylus C84 InkJet Printer
HP DeskJet 3820 InkJet Printer Logo
41 people viewed this question
Ben Johnson
