Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
JVC HD52Z585 green lines / remote service menu
I have an HD52Z585 "52" set which displays green vertical lines as the set warms up. It gets progressively worse until the image is un-viewable.
I have read that resetting the HDMI port from the service menu may
resolve this but I do not know how to get into the service menu. My
set is out of the warrantee period so I would like to try this myself
before I have to pay for a service call.
Any ideas, suggestions is appreciated.
The green screen you read about is a solid color only when you select digital input. If you are getting green lines in any other input the reset will have no affect at all.
You will need to have the TV serviced, there is a possibility that the service center can use the reset jig to correct this. But it could be more serious.
Posted on May 11, 2008
JVC HD-56G786 Green Vertical Lines
am thank if you see it in your menu..and on ever channel..you have a bad dmd bord or dmd chip
Dec 24, 2013 | Televison & Video
Green tint
Posted: Wed Jul 18, 2007 5:50 am Post subject: JVC Service Menu Codes - Plasma, LCD, CRT, RPTV icon_quote.gif NOTICE: MUST READ BEFORE USING SERVICE CODES!!!
this information for those that are qualifiedand trained to do TV repair work. Entering or making changes in servicemode by untrained persons can cause significant and permanent damage toyour television. If you are not qualified to service your television,please DO NOT ENTER these service menu codes.
-Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
- The buttons on top of the remote are set to TV & VCR respectively.
- Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
- The main service menu will be displayed with choices #1 through #9.
- Press one of the corresponding number keys to enter that menu.
- Use the {CH+} {CH-} buttons to navigate within a menu.
- Use the {VOL+} {VOL-} buttons to change the values.
- Use the {MUTING} button to memorize the changed value.
- Use the {BACK} button to exit the service menu.
Jul 05, 2008 | JVC AV-48WP74 48" Rear Projection...
My hdmi port in the back of the tv does not work..i have never used this before and we bought a ps3 when i hook it up all i get is a green screen but i know it is not my ps3 or cable because they both work...
1a) make sure the two slide switches on the top of your remote are set
to TV and VCR (both to the left).
1b) Press SLEEP TIMER and make sure it is set to "0" minutes. (Only on
screen for 2-3 seconds)
2) While "0 minutes" is being displayed on the screen, press DISPLAY and
VIDEO STATUS at the same time. This will pull up a service menu on
the screen.
3) Press the option # 2 (SELF CHECK) on the service menu
4) Turn the TV off and allow the set to run its normal cool down
process.
5) Turn the TV back on and set the TV back to DIGITAL IN mode by
pressing on the INPUT button.
Jan 09, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
LCD TV vertical line
If the line is vertical and "One Pixel Wide" (Pinstripe) then the LCD Panel is bad and needs to be replaced. Contact 1-800-SAMSUNG to set up service.
Jul 14, 2009 | Televison & Video
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
JVC HD-52G786 Service Mode
Sure. I'm not sure if you can do it without the original remote, though. On my remote, you need to have the tv turned on, then press the sleep timer, then press the display and video status buttons simultaneously. This enters the service mode. Then, you should see an option for self-check (#2 i think). Enter that, then you should see 2 vertical columns of different inputs. From that screen, power the tv off. This resets all the ports on the tv.
Jun 18, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Jan 30, 2008 | JVC AV-56WP30 56" Rear Projection...
HDMI input failure
Hey guys, had the same problem. Found this solution on the web. Worked for me.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is reenabled.
Here’s how to get to Service Menu:
simultaneously.
This should work.
Oct 06, 2007 | JVC HD-52Z575 52" Rear Projection...
JVC Vertical Problem
You need to adjust the vertical height in the Service menu.Press the SLEEP TIMER key and set the SLEEP TIMER for 「0 MIN」. Then press the DISPLAY key and VIDEO STATUS key of the remote control unit at the same time to enter the Service menu.In SERVICE MENU, press the FUNCTION ▼/▲ key to select any of the SUB MENU items. (The letters of the selected items are displayed in yellow.)You want #2 DEF - go to sub-menu and look for the height adj. FUNCTION / key Setting (adjust) the SETTING VALUE of the SETTING ITEM. When the key is released the SETTING VALUE will be stored (memorized). EXIT key Returns to the previous screen.
Aug 22, 2007 | JVC AV-27320 27" TV
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
241 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
