Question about Linksys (RT31P2) Router
Unable to get a IP address to my workstation at home,
I am now unable to get a IP address to my computer. I have comcast
as my ISP and vonage for my VOIP. everything was working fine until
last week. I have reset the both my BB router and cable modem.
If I plug my laptop in directly to the modem it works fine, if I plug my desktop directly into the modem it still does not work.
My vonage works fine so the connection between the cable modem and router seems to be good.
I have put in a new nic and disabled the onboard nic. Still get the same indications
  • serra baby
    serra baby May 11, 2010
    hello!
    -- are you using the same ethernet cable if you connect your desktop to the router?
    -- what is the ip address of your desktop if you connected it directly to the modem? how about to the router?
    -- what about your laptop? what are the ip address if you connected it to the mpdem and to the router?
  • 33 Answers
Just wanted to clarify
* have you tried connecting desktop and laptop straight to the router? (because with your statement you only connect both computers straight to the modem and only the laptop works fine).
Posted on May 01, 2008
We need to get the printer to recognize the network server name or IP address. At present it says "Unable to connect to (DC-260-795622). The server name or IP address may be invalid.
Ensure that all your network settings on the printer are correct, especially the DNS settings. Are you able to ping the printer from a workstation? Maybe you have a bad cable connecting the printer.
Jan 21, 2015 | Xerox Office Equipment & Supplies
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
I'm unable to get wireless connection to the internet after i replaced a new modem. Directy connection from modem to laptop is fine. Both my laptop and PC are able to detect the wireless network but are...
disconnect all the connections from the router. connect only the computer to the port 1 on the router. check the lights on the router. Reset the router for 30 seconds . unplug the power to the router. plug it back in. wait for 1 minute.now check the IP address on the computer. Win XP = click start ==> run ==> type cmd in run box and click ok. you will see the command prompt. in the black window type ipconfig and hit enter. now you will get the IP address and the Default gateway. Default gateway will be the number of your router. This will open the roputer set up. not check the settings on the router. If you connect the modem to the router, it works. now reconfigure the router as per ISP. Click Here for more info about how to set up router
Nov 18, 2009 | Linksys EtherFast Cable/DSL Router
New computer (Vista) does not connect to internet. We have vonage VWR-VR D-link router and SBC Yahoo.
If you want this computer to connect wrielessly, go to Control Panel > Network and Sharing Center and click on Connect to Network. Select your router's signal from the list and click on Connect. It might require you to enter a network key. If you don't know your network key, call your ISP.
Apr 18, 2009 | D-Link Vonage-enabled Wireless Router...
Hawking wireless router (HWRN1A300N) will not connect ot internet
First of all - your ISP has nothing to to with DHCP. DHCP is handled internally by your router (or DHCP server).
If you did not configure your router otherwise, it should hand out an IP address automatically.
If you ipconfig shows that you have an IP address, then I assume that this address is manually configured.
You should set everything to automatic until you know it works.
So...
Go to your start menu -> Control panel -> Network connections.
Right-click on "Network Connections" and choose "open".
Look for your "Local Area Connection", if you are wired into the router, or something like "Wireless Network Connection" if you're using wireless.
Right-click "Local Area Connection" and choose "Properties".
Double-click "Internet Protocol (TCP/IP) and see that both "Obtain an IP address automatically" AND "Obtain DNS server address automatically" are selected.
Click "OK" twice and make sure that all property windows are closed.
Go to the command prompt and re-do "ipconfig /all" (No quotation marks of course).
Check the line that says DHCP server, it should be the same IP as your Default Gateway (your router).
If this does not work for you, copy the result form that command here and I have another look.
If it works, please come back and leave a comment. This might help others with the same problem.
Dec 28, 2008 | Hawking Computers & Internet
Unable to connect to the internet
Open your web browser. Type in 192.168.1.1 into the address bar A dialogue box will pop up. Leave the username field blank and the password is admin. Once the webpage is displayed, scroll down until you find Local IP Address. Change this to 192.168.2.1. Scroll down and click save settings. Now attempt to access the intnernet.
Dec 21, 2008 | Linksys Computers & Internet
2wire 2700HGV cannot detect wireless Linksys IP camera WVC54GC
Purchase a different router and return the 2wire to the ISP explaining it is not compatible with your equipment at home. You may need to provide them with the new router's MAC address.
Nov 21, 2008 | 2wire 2700HG-B Router (2700HGB)
Just bought a laptop and can't get comcast to work with net gear. My son's lap top worked when he lived with me.
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Aug 10, 2008 | NetGear WGR614 Wireless Router
Unable to conect to dodo isp
First make sure that you have a valid connection to the router and that you have a valid IP address.
(note: for a wired connection you should have a link light on the numbered port of the router to which your computer is connected. You should have an IP address in the range 192.168.2.x. To check your IP address, click on Start, Run and type in command. Click OK. Now type in ipconfig and hit enter. Your IP address will be listed.)
For the F5D5230-4, F5D6230-3
Open a Web Browser
1. In the address bar type http://192.168.2.1
2. Click on Intial Setup
3. Select PPPOE and click Select
4. Type in your username that was assigned to you by your ISP *
5. Type in your password that was assigned to you by your ISP twice
6. Leave Service Name blank
7. Click on Enter
8. Click on Status in the left hand column
9. It should now show Cable / DSL Connected under the Internet column
For the F5D5231-4, F5D6231-4, F5D7230-4, F5D7231-4, F5D7231-4P, F5D8230-4, F6D3230-4
Open a Web Browser
  2. Click on Connection Type in the left hand column under Internet WAN heading
  3. Enter your password if any and click Submit
  4. Click on PPPOE and then click on Next
  5. Type in your username that was assigned to you by your ISP *
  6. Type in your password that was assigned to you by your ISP twice
  7. Leave Service Name blank
  8. Click on Apply Changes
  9. Click on the Home link at the top of the screen
  10. It should now show Connected as the Internet Status at the top right hand corner of the web page
Apr 24, 2008 | Belkin (F5D5231-4) Router
Can not connect web cam and view outside of home network
Try to see your modem config and send the data.
regards
Jan 06, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Linksys (RT31P2) Router Logo
156 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
