Question about Polaroid TLA-01511C 15 in. LCD Television
Poloroid monitor when I turn it on it will work normaly for 15 seconds or so then goesblack untill it is turned off end restarted. is there a timer or something Im not seeing or possibly a setting
  • RAEQUINTERO Sep 26, 2008
    I BOUGHT THIS SAME TV FOR MY DAUGHTER LESS THAN A YEAR AGO. LAST NIGHT THE PICTURE WENT OUT BUT SHE STILL HAD THE SOUND. I DIDNT PAY FOR THE WARRANTY. PLEASE HELP ME THATS ALOT OF MONEY TO GO IN SUCH A SHORT TIME
  • mjwatki Oct 21, 2008
    I have the same problem, i turn on my tv and it just goes black. I still have sound though. I read one of the solutions, but i cant figure out where the power supply board is.
  • Polaroid Master
  • 5,568 Answers
I see this is an old message so you have probably tossed or retired this set.
The problem is likely in the power supply section of the set.
If it is elsewhere in the set, the power supply may be cycling to avoid further damage or even a fire.
I suggest you not leave this set plugged in anywhere it cannot be seen.
Posted on Jun 17, 2008
    Problem Solver:
  • 9 Answers
Check The Caps on Power Supply Board, Which is a common problem ..
Posted on Jul 31, 2008
Need OSD Lock out removed permently Please
have you tried the following steps:
  • Press and hold the "Power" key on your monitor to turn it on. Press the "Menu" button for 15 to 20 seconds to cancel the OSD lockout message.
  • Press the "Power" button on your monitor for several seconds until you see the OSD lockout message disappear. Unplug and re-plug your monitor power cable back into the outlet if the OSD lockout message is still displayed.
  • Turn your computer's monitor off. Press the "Menu" button for 15 to 20 seconds and power your monitor back on.
  • Read more : http://www.ehow.com/how_10015851_fix-osd-lockouts.html
    Apr 09, 2015 | Microsoft Windows 7 Home Premium 64BIT...
    I installed a Woods 59720 timer switch to control a small bathroom fan. First time I turned it on 5min cycle it worked fine. Now, it runs only 10-15 seconds, then turns off. Set for maximum 30 minutes, it...
    I looked it up and it sounds like your unit is defective. It should run for 5, 10, 15, or 30 minutes. There are no "seconds" options. The timer chip/module may be defective.
    Gary
    Sep 04, 2011 | Woods 59720 Automatic Wall Switch Timer...
    Have Kenmore 85501 Air Cleaner. Unit will not restart after power failure. Send unit to Sears Service Center but they declined to fix unit. Tried to hold timer and function buttons for 5 seconds and...
    Turn the Master ON/ OFF Switch to OFF and unplug the unit. Wait 12-15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set your controls. The 12-15 minute timeout should have allowed the unit to reset itself.
    Apr 16, 2011 | Kenmore EnviroSense 85501 Air Purifier
    Polaroid 15" HD Widescreen LCD 1511-TLXB, turn on, stays on for about 30 seconds to 1 minute and then screen goes black, no sound, no menu
    Do you have to turn it back on with the remote after this?
    If so, then you may have set a timer by accident through the menu system.
    More information would be required.
    Aug 04, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
    Monitor restarting randomly
    Rarely does a monitor go out due to drivers. Try another monitor and verify that it isn't the computer (it isn't). If the power light goes out it is the power supply (usually inside) the monitor. If the light stays on, it will most likely be the backlight power unit. Browse the internet for the model and parts. Newer units are difficult to find.
    Apr 29, 2009 | Computers & Internet
    Need manual for kenwood tk-270 transceiver does any one no were i
    Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
    Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
    How to use self timer in Can Sd400
    Press the timer button until the clock symbol is displayed. Point the camera at your subject and take a shot as you normaly would. As soon as the second switch on the shutter button is pressed, the 10 second countdown will begin. A yellow lamp will flash every half a second until the last second where it will remain lit and then take the picture.
    Apr 05, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
    Westinghouse side by side fridge is warm but freezer seems alright, checked and found evaporator freezing up not allowing airflow into fridge? Note cleaned all dust from Condensor and still same, fridge...
    Locate the defrost timer, turn the clutch head screw until you hear one click. This will actuate the defrost system. After 18-22 minutes the defrost should should have taken place and the compressor should restart. If the compressor does not restart after the time period the timer is at fault and needs to be replaced. Turn the clutch head screw to the second click and the compressor will restart. If defrost does not take place the problem is in the defrost heater circuit. Possibly bad heater or defrost termination switch.
    Jul 29, 2008 | Refrigerators
    Turn on computer
    i think u must have problem with ur power supply in mother board and for the hdd i think better u change the HDD or run a sever scan text on ur HDD i think ur HDD might have bad sectors wirtten
    Nov 28, 2007 | ASUS P4V8X-X Motherboard
    Polaroid TLA-01511C 15 in. LCD Television Logo
    125 people viewed this question
    Top Polaroid Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
