Question about Kodak i40 Path-Through Scanner
I 40 knocking sound on scan
When I scan I hear a noise that is associated with the rollers a cross between a clicking and a knocking. Like a flat tire.
Try cleaning the rolls with the recommended kodak cleaners
Posted on May 26, 2008
Knocking noise
see the video attached. However LUBE the rollers bearing front+back with wd-40
God bless you
Nov 12, 2013 | Horizon T203 Treadmill
I have a golds gym cross walk 570. when belt is rolling it makes a loud noise coming from the motor. i have disconnected the belt from motor and run motor wide open and does not have this sound. unit still...
Hi, i strong recommend you.
1) LUBE the bearing of Roller, the noise can be the Bearing of
Roller.
2) And after LUBE if , the noise is coming again replace the Roller.
3) However you can test the motor outside by turning by hand. Lube slight the shaft with WD-40 and Run again, if the motor make noise Replace the Ball Bearing, or replace completely the Motor,
Oct 27, 2017 | Golds Gym R CrossWalkR 570 Treadmill
Knock while driving off on cold engine
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make knocking noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
CAR NOISE ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/car-noisesnoisy-cargrinding.html
These will help.
Thanks.
Dec 07, 2012 | 2008 GMC Sierra Denali
Indesit tumble dryer IDC 75 making knocking noise
the only things that will cause this to happen are the rollers or the blowewr wheel.
May 18, 2012 | Dryers
Knocking noise when reversing
check your lug nuts. also check the axle shaft joints.
Jan 02, 2012 | Nissan N Z 38 POWER CAT Cars & Trucks
My dryer is making a loud noise. its so loud that you can hear it through the whole house. What could it be? It drys clothes but we can't handle the loud noise
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Good Luck,
I hope this helps,
Aug 15, 2010 | Dryers
My Maytag Model MDG8057BWW first squeaked then began loudly knocking. What is causing this; everything is drying well otherwise.
The drum to the dryer has a belt with a belt tensioner on it. The roller for the tensioner has a frozen bearing that will not turn giving the roller a flat spot on it. This is causing the noise you hear. sears.com can provide you parts to service this belt and roller as a kit form for replacement
Apr 12, 2010 | Dryers
Loud noise and clothes stuck in dryer drum
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS It sounds like you have two problems. #1 Problem...Noisy rollers #2 Problem...Faulty front door felt seal, causing the clothes to get caught.
Sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor and door seal. You can now inspect/repair/replace the felt door seal. Now is also a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 21, 2009 | GE DBSR453EBWW Electric Dryer
Lexmark t644 making knocking noise when printing. I sprayed some air duster around the rollers but the knocking still persists.
Could be caused by the fuserroller. If the machine has been out of use for some time or if you do not print very mutch, the pressure roller of the fuser gets flat spots witch can give a knocking sound.
Gerrit Jan
Nov 05, 2009 | Office Equipment & Supplies
Kodak i40 Path-Through Scanner Logo
118 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
