Question about Proscan PS56670 56" Rear Projection Television
Proscan PS56670 56" rear projection TV
My TV was mfg in 1998. After the tv warms up the screen gets warped. This takes about 20 min. I had a tech look at it in Dec and at first he thought it was a convergence problem. After checking it out he thought it was a "pincusion" problem. With the rear cover off the tv worked perfectly until now. It will work fine if I put a fan behind it. Obviously there is some kind of thermal issue. I am not even sure if it is worth fixing. Can someone tell me what I should do. Is it worth fixing?
  • TurboII Apr 29, 2008
    Thank you. That is what I was figuring would be the best thing. I hoping I could find someone to take it for free. Might be worth it to someone who knows how to fix it.
  • 2,323 Answers
For a 10 years old TV, it might not be worth fixing it. Save your money to get a new one once this one gives up.
I would keep it running using with the back cover off using that fan to keep it cool.
Hope this helps.
Posted on Apr 29, 2008
My 53UDX10B after maybe 20-25 mins. the screen goes blank and still has the sound. I feel as though something is getting too warm and goes pictureless. After some time I turn it back on and it repeats...
yes u have a lot loose connection on the deflection board , u need to solder the flyback , power supply and vertical , and all around this component , also u can hire a tv tech and do this job probably $200
Sep 03, 2010 | Hitachi 53UDX10B 53" Rear Projection...
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
Splitting a RCA Proscan 60 in 2
If there are plastic plugs on the sides of the tv (4) then you can take them out and expose a screw that if taken out will allow for this, otherwise you will have to get creative. good luck
Aug 29, 2009 | Proscan PS52690 52" Rear Projection...
Toshiba 50h72 picture and sounds takes 20 min to warm up
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Sep 09, 2008 | Toshiba 50H72 50" Rear Projection...
Picture gets darker
Apparently there is a loose connection somewhere. Please have unit checked out by a pro tech
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Proscan Projection screen warped
Just had mine do this same thing today. Looks like its time for a flat screen. Sucks to spend the money though :(
Feb 03, 2008 | Proscan PS50700 50" Rear Projection...
Proscan 5700 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Proscan s56700
call tech ...suggest checking horizontal drive.
Nov 12, 2007 | Proscan PS56700 56" Rear Projection...
Scrambling for first 15 mins
That is the exact problem I am currently having with my toshiba 50 in. I did some reading and it sounds like there is a temperature drift across one of the capacitors on the board and it takes longer and longer to warm up. Havent fixed it yet...
Mar 18, 2007 | Toshiba TP50H50 50" Rear Projection...
Televison & Video Logo
171 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
