Magnovox TV My two year old Magnovox started to develope a problem on the screen, wheras the top of the picture screen, uh...sort of "folds over" like it doesn't have enough room at the top. It's like if you held a photograph up and the top of it just rolls over onto itself. Someone has told me that it may have something to do with the "vertical" system. Is it something that I could repair or replace? Thanks, WCYancey
I've taken the TV to a Magnavox repair shop.
Posted on Apr 30, 2008
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
I have a 8 year old 57in Sony projection HDTV,when the picture is dark you can see faint blue lines in a curved arch like pattern across the screen.Any ideas? Thanks
The tv problems is call a convergence picture problems,it is just starting to developing.This problems when it is fully developing into a convergence picture problems to the tv eventually.Tv will develope into a colors lines R,G,B mis alignments,have a colors shadow pictures or into a picture 3D look alike.Eventually the tv convergence board will dies,have to have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.This problems the tvs shops will cost u like $300-350 for parts and lobors.
Aug 13, 2011 | Sony KP-57WS500 57" Rear Projection...
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
HORAZONTAL TRACE OVERLAP AT TOP OF SCREEN. MY TOSHIBA 32D46 TV HAS DEVELOPED WHAT LOOKS LIKE A FOLD OVER OF THE TRACE AT THE TOP OF THE SCREEN, ABOUT 2 INCHES. CAN THIS BE ADJUSTED OUT BY ADJUSTING THE...
Usually that is caused by a part failure. The vertical deflection ckt is most likely the roblem. Sometimes it's just a cap usually a 100mf right next to the vertical ic chip. Or it can be the ic itself. Unfortunately you can't adjust it out.
Feb 23, 2010 | Toshiba 32D46 32" TV
I HAVE A JVC AV27D302: THE PICTURE IS FOLDED OVER
For how many years this TV with you? Most tv now a days after few years of using vertical IC solder started to dry(dry solder) you can try to re-solder or you may check also two capacitors (100uF/35V) for most JVC model has this symptom with this parts changes its electrical characteristics. If still problem persist replace vertical IC. Hope his helps, Good Luck
Feb 14, 2010 | JVC AV27F476 27" TV
Television Picture Height
Please view the solution here: http://www.fixya.com/support/t4019796-toshiba_27a34_27in_am_getting_white
Dec 31, 2009 | Toshiba 27A34 27" TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
There is a band developing
The band is developing across both the top and bottom of the screen it is called cinemascope picture. it is a vertical failure. it is not a major problem. it is on you accrding to cost of repair. it is due to less supply or part failure in vertical section.
Sep 24, 2007 | Philips 32PT5441/37 32" TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
