Question about Lexmark E232 Laser Printer
LED lights permanently on
Hi - I have just inherited this printer from within the company, and fitted a new Toner Cartridge and Photoconductor Kit.  Out of the five LED lights, the second one and the bottom one remain lit.  I have reset the Photoconductor counter as instructed on the information that came with the parts, but now both the photoconductor/toner light and the exclamation light remain on.  Any ideas?  Thanks
  • elainechisho Oct 29, 2008
    ideas? Thanks
  • ttilav58 Nov 04, 2008
    I am having the same problem. While researching the problem I found on the lexmark web site that this printer has a recall if purchased before 2004 and a possible recall if purchased after 2004. Check the website for additional information.
    Genius:
  • 2,035 Answers
Grinding noise
could be the laser unit on top of the printer out of whack -i have the same fault also
Jun 29, 2012 | Lexmark E120n Laser Printer
Orange light is constantly flickering. I have put a new toner cartridge and now a new photoconductor kit in and it is still flashing
Please make sure to reset the printers' pc count. Below are the steps.
1. open the front cover. Leave the printer powered on. 2. With the front cover open, press and hold the stop/cancel (pattlnk_392009_184-e260%20stop%20button.gif) button. 3. Eventually all of the lights will begin flashing, indicating that the photoconductor page count has reset. When you see this light sequence, let go of the pattlnk_392009_184-e260%20stop%20button.gif button. 4. Close the front cover.
If you wish to confirm that the photoconductor page count has reset, print a menu settings page.
Jul 11, 2011 | Lexmark E260dn Laser Printer
The printer toner light is continuously flashing even after putting in a new cartridge
After installing a new cartridge and the blinking light is on Toner Low, it means that the photoconductor is almost full and should be replaced soon. Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, replace the photoconductor kit.
For further assistance, please call Lexmark Technical Support.
Jun 14, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
My toner cartridge was recently replaced (we use the proper cartridges, not refills) and within about 3 weeks (sooner than last time) the "toner low" light is flashing. The print quality is still perfect....
Whenever you replace the photoconductor kit, you will also need to manually reset the photoconductor page counter. Visit the Lexmark website at http://bit.ly/8YJwFU, for the instructions on how to reset the pc page count. You can also contact Lexmark technical support or your authorized service provider for additional assistance.
Sep 24, 2010 | Lexmark E250dn Laser Printer
Toner is changed but toner led flashingr
The flashing toner light indicates that the photoconductor kit needs to be replaced.
Use this Lexmark Part# : 12A8302 to order. After replacing the drum cartridge counter will have to be reset, Use the following steps.
1. Open the front door (press button on left side).
2. Press and hold the cancel button (x button) until all the lights flash in order.
3. Then close the front cover.
This will reset the drum counter to enable continued printing.
Jul 21, 2010 | Lexmark E232 Laser Printer
We have a Dell 1700 at our office and the drum light is flashing and the page prints out stating the photoconductor kit is at the end of its useful life - so we ordered a new one. We received and installed...
There is nothing on the photoconductor unit to 'tell' the printer that it is new, you have to do this yourself, by following the photocinductor reset procedure (it's in the manual, or
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
May 12, 2010 | Dell 1700n Laser Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
Power up init fails
When you replaced the photoconductor, did you go through the procedure to reset the photoconductor counter ?
There's no chip on the photoconductor, so you need to reset this manually
Photoconductor Reset Procedures:
Step 1:
Open the front door and hold the
Cancel button until all lights begin to cycle.
Step 2: Close the front door. The warning
clears and the counter resets to zero.
Step 3: Press Continue to resume printing.
Mar 01, 2010 | Lexmark E120n Laser Printer
Toner light still blinking orange after new toner installed. Rebooted printer, light still blinking.
It means you need to replace the photoconductor kit (the bit the toner fits into) reset information is supplied with the new photoconductor kit.
Oct 15, 2008 | Lexmark E232 Laser Printer
Printer doesn't like new cartridge
To reset this error, open the front door then press the cancel button for 3 seconds - all lights will cycle, close the front cover. The counter is now reset
Sep 02, 2008 | Lexmark E240 Laser Printer
Lexmark E232 Laser Printer Logo
509 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
