Stuttering Sound Settings on high do not help, VLC will operate normally but that is not the fault. Why wont other industry standard software operate?? Within the multmenia environment??
    Genius:
  • 3,422 Answers
Ok so let me clear your doubt.See the fault lies no where it depends on the software.Actually WMP,Cyberlink and all these have the volumes set to a particular limit by the softweare developer.So that's why you will have to shift to another software which can give you a full boost.One of them is VLC..i hope im clear.
If you have anymore doubts you can ask me..
Please don 't forget to rate or accept the solution as fixed over here and also the one which you posted..
Posted on Apr 29, 2008
What when coming to a full stop and applying the clutch and the break sometimes causes a thumping sound or stuttering sound. At times when releasing the break and the clutch th
You should only put the car in neutral then apply the brake.
If you continue to drive with the brake and the clutch it's going to burn out the clutch.
Just when you are coming up to a light take the shifter out of gear and then put it in neutral then apply the brakes.
You will notice the car will drive better
Hope this helps.
The stuttering and jerking motion means usually that you are starting at a to high of a gear or to low. The brake will cause the situation you are having. if you are applying it any time during shifting
Apr 17, 2015 | 2001 Toyota Tacoma Idle Speed Regulator 01...
No sound when using Sony Camcorder
Did you check that you didn't mute the sound when recording?
May 11, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
No sound on my computer except when I go to one website
Make sure you have the volume turned up and not muted.
Check your Sound Audio settings in the Control Panel. Click Start/Control Panel and check the settings.
You could right click on the megaphone at the bottom right near the time to get to the Audio Sound settings.
You could try downloading and reinstalling the Audio Drivers.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Audio drivers.
Try the VLC Player. I have seen it solve issues with sound devices. It comes with drivers and codec.
Try using VLC as your player. Go to www.google.com and in the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Download and install it. It downloads and installs in 3 minutes or so. It's a very fast player, smooth and it can play just about any type of dvd formats and media. It's totally FREE.
Apr 29, 2012 | Computers & Internet
I WANT TO WATCH A MOVIE BUT I CANNOT HEAR THE SOUND HELP ME.
Go to http://www.codecguide.com/ And download and install the kl codecs pack, standard and install them and you will be able to see and hear any video or movie.
Apr 19, 2011 | Microsoft Windows Vista Ultimate Edition
Cannot play .mkv file at VLC
Hi. I would Suggest you download the latest version of VLC and install it as a full installation.
This is the website where you can DL the latest version of the VLC player. http://filehippo.com/download_vlc/
Hope This Helps
Jun 06, 2010 | VideoLAN VLC
Creative Sound Blaster Audigy Value Problem
Make sure that memory resident programs have been disabled. Defrag your hard drive as well so that audio files you are recording are continuous files on your drive.
Jul 16, 2008 | Creative Labs Sound Blaster Audigy 2 Value...
Intermittant stuttering/surging when starting
Rough idle or stalling. Ignition timing is controlled by the electronic control ignition timing system. The standard reference ignition timing data for the engine operating conditions are pre-programmed in the memory of the engine control module (ECM). The engine operating conditions (speed, load, warm-up condition, etc.) are detected by the various sensors. Based on these sensor signals and the ignition timing data, signals to interrupt the primary current are sent to the ECM. The ignition coil is activated, and timing is controlled. Check for any fault at: Spark plugs faulty Replace plugs Ignition wiring faulty Replace wiring Ignition coil faulty Replace ignition coil High tension cord faulty Replace high tension cord
Jun 06, 2008 | Hyundai Motor 2003 Elantra
Stuttering Sound
Hi again,
I'll let you know soon if there is another solution to fix it within your two players..
Apr 30, 2008 | Televison & Video
DVD player sound
is the dvd a retail dvd, or a copied dvd? can you play music cd's ok? if the sound is stuttering, you may have too many other programs running. Check the systme tray amd close down all other apps and icons. most likely a problem with the laptop needing more memory to play the dvd. also try another dvd player like vlc or divx.com, or xvid.org for updated player codecs.
Aug 27, 2007 | Gateway MX3702 Notebook
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
