Question about Durabrand W600 Shelf System
Can't heat radio
My system turns on & will play cd's, but I cannot get a radio station to pick up at all!! Why?
Hi There Laura,
For you to get radio reception then you will need an aerial...
The FM stations are very weak and thus need a good long aerial to collect these weak signals.
Some receivers need the aerial to be a "loop" so and on the rear of the receiver there will be a special two port aerial connector for the FM..
You dont say where you are but if you are in the "outback' then a good long aerial will be needed...
The same can be said for the AM radio signals these are much lower in frequency but still need an aerial.
There is a difference with the AM signals as they also need a good earth as follows.
On the back of the receiver there will be an aerial connector marked AM and it will show an earth connector and and aerial connector.
There needs to be a good earth connected to the earth connection and another long wire connected to the aerial connector.
The earth should be a metal spike about 500mm long driven into the soil outside in the garden
and connected to a wire which comes inside thru the window to the earth connector on the rear of the receiver.
The aerial wire must not be connected to earth at all, but insulated.....
this wire connects to the AM connector out thru the window and up to the nearest high point. Like a tree or a pole...NOT A POWER POLE as that dangerous.
When you connect to the tree use a piece of plastic rope or something to insulate the wire from what ever it touches, as the radio signals are not allowed to come in contact withthe earth until they get inside the receiver...
You can use a wire with a plastic cover on it if you like..
You may wish to ask your neighbour if you can look at his aerial connections and learn how its done...
He wont mind.... unless you are "outback" and the nearest neighbour is 100miles away..
That makes it more difficult.
If you get stuck ask here again and I'll pass on more detail for you..
Cheers for now
From YUBEUT..
Posted on Sep 27, 2008
My am radio does not work in suzuki
A quick trip to the dealer a Suzuki dealer will solve the problem. I believe that the issue is in the wiring, easily fixable by a mechanic
Jan 23, 2014 | Car Audio & Video
Hi, I was wondering if my LG DVD Micro HiFi System FB163, could play an the radio as an alarm? If so how?
Hello, To set a radio station as your alarm -
  1. Press and hold "timer" for two seconds.
  2. All the functions DVD/CD/USB/Tuner will flash for two seconds.
  3. Press "set" when the mode you want to be woke up by is showing.
  4. If you pick "tuner" then "play" and "record" will flash alternately flash in the display.
  5. Pick one by pressing the "set" button.
  6. Then select the preset station you want to wake up to.
  7. Now press set again.
  8. You will now wake up at the time and radio station you selected.
Regards, Tony
Mar 24, 2011 | LG FB163 DVD/DivX USB Micro system Shelf...
I cannot get the AM radio stations to play or the CDs to play on the AIWA XR-M10. FM stations come in fine.
as for the am radio you need to connect the am aerial to pick up am frequencies as for the cd player need a bit more info on that
Oct 14, 2010 | Aiwa XR-M10 Shelf System
Wont play through stereo
the changer plays through the fm on the radio, you need to find out what station it is tuned to. should be between 88 and 95 or so. you could just try seeking until the changer is picked up.
Jul 09, 2010 | Pioneer CDX-FM687 6-Disc CD Changer
The FM stations are not playing in my 1996 Nissan Maxima.
make sure the antenna is plugged into the back of the factory radio.
Jan 05, 2010 | Car Audio & Video
I have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Dec 18, 2009 | Bose Wave Radio
Cant pick up any radio stations after battery was changed
probably need the anti-theft code to get the radio working again
Jul 15, 2017 | Sony CDX-M600 CD Changer
Jensen car stereo
just turn the changer on, make sure it is playing a disk, (and you know whats playing) the press the scan function on your radio til it picks up that signal and lock it in.
Nov 05, 2007 | Jensen XCH6RF 6-Disc CD Changer
Durabrand W600 Shelf System Logo
108 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
