Error Message: Direct CD; This driver will be disabled. Contact Manufacture ( Roxio )for an update that is compatable with this version of Windows. (XP home edition )
  • 2 more comments
  • flaesor Apr 29, 2008
    My computer model is HP Pavillion a 1400y XP home Edition
    According to your instructions it seems that I won't be able to write to my blank Cd's
    this Program was supposedly supplied when I bought it.I assumned I would be abled to write to CD's
    Please Cancell this Progra Refund my money
    Genius:
  • 3,422 Answers
I've got fe links which will help you out:
1)Please CLICK HERE
2)Please CLICK HERE
3)Please CLICK HERE
Goodluck,
Please don't forget to rate the solutoin
Posted on Apr 29, 2008
  • 3,037 Answers
From microsoft
http://support.microsoft.com/kb/294479
Method 1 loadTOCNode(2, 'resolution'); Click to select the Don't display this message again check box, and then click Continue.
Method 2 loadTOCNode(2, 'resolution'); 1. Click Start, and then in Control Panel, double-click Add/Remove Programs to locate the Easy CD Creator 5 Platinum program. 2. Under Currently installed programs, click Change. 3. Click Next. 4. Click Modify. 5. Click Next. 6. Click Direct CD. 7. Click This feature will not be available. 8. Click Next. 9. Click Install. 10. Click Finish. 11. Click Close.
Let me know if you have any further questions, thanks
  • Benjamin Patri
    Benjamin Patri Apr 29, 2008
    CAUSE
    loadTOCNode(1, 'cause');
    This behavior can occur because Roxio DirectCD Creator versions 5.00, 5.01, 5.02, and 5.02a are not compatible with Windows XP.
  • 149 Answers
Did you buy the software or is it a trial?
  • 13,433 Answers
If you dont need the direct cd function or the roxio program which is outdated I recommend you uninstall it and then after install the newest version or another software like
nero
www.nero.com
DirectCD driver update
use system restore...or uninstall roxio and than reinstall....better u should go with system restore
Jun 15, 2010 | Roxio Easy Media Creator 10 Suite
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
I re-install roxio creator 9, after install windows7, and don't recognize any dvd-cd unit installed, so i can't run roxio creator 9. i have a hp notebook, and roxio creator 9 came with it? what can i do?
Windows7 is still being developed and as far as I know it has some compatibility issue with many hardware etc..Check compatibility with manufacture before you look any further.
Jul 02, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
This version of Windows does not support this version of Roxio DLA. This product, which was created by Roxio, Inc., has been blocked from running because it might keep your computer from starting correctly...
Getting older programs to run on Windows XP Getting older programs to run on Windows XP Most programs run properly on Windows XP. The exceptions are some older games and other programs that were written specifically for an earlier version of Windows. To run your program on Windows XP, try the following:
  1. Run the Program Compatibility Wizard. As an alternative, you can set the compatibility properties manually.
  2. Update your program, drivers, or hardware.
These options are covered in detail below.
The Program Compatibility Wizard This wizard prompts you to test your program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows 95, set the compatibility mode to Windows 95 and try running your program again. If successful, the program will start in that mode each time. The wizard also allows you to try different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
If compatibility problems prevent you from installing a program on Windows XP, run the Program Compatibility Wizard on the setup file for the program. The file might be called Setup.exe or something similar, and is probably located on the Installation disc for the program.
To run the Program Compatibility Wizard
  1. Start the Program Compatibility Wizard.
  2. Follow the instructions in the wizard.
Dec 19, 2008 | Computers & Internet
Operating system error while installing roxio
Linux is much better than windows as for one you dont have to worry alot about viruses but pretening on installing that software maybe its just not compatible with windows
Dec 17, 2008 | Microsoft Windows XP Professional
BCCode Error
CAUSE loadTOCNode(1, 'cause'); You may receive this error message when Windows attempts to use device drivers that are incompatible with Windows XP. uparrow.gifBack to the top
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue, verify that each device in your computer uses a driver that is compatible with Windows XP. To do so, follow these steps: 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties dialog box, click the Hardware tab, and then click Device Manager. 3. For each device, use the following steps to verify that it is using a Windows XP-compatible driver.NOTE: To narrow down the search, begin with devices that have been disabled. A disabled device has its icon overlaid with a red X.
a. Double-click the device name to open the device Properties dialog box, and then click the Driver tab. b. Examine the driver version. All Windows XP drivers should be version 5.1.2600 or later. c. If you are not sure about the displayed version, examine the driver date. Drivers created before the year 2001 may not be compatible with Windows XP. 4. After you identify an outdated device driver that may be causing the problem, follow these steps to update the driver: a. Insert your Windows XP CD into the CD-ROM drive. If Setup starts automatically, quit it. b. In the device Properties dialog box, click Update Driver to start the Hardware Update Wizard. c. Click Install from a list or specific location (Advanced), and then click Next. d. Click to select the Include this location in the search box, and then type your CD-ROM drive letter in the space below. For example, type D:. e. Click Next. f. Follow the on-screen instructions to finish updating the driver. 5. Restart your computer if prompted.
Sep 20, 2008 | Microsoft Windows XP Professional
Incompatible Driver(s)
I would uninstall Photosuite.
I don't think that Roxio is supporting that program anymore. I have version 7.0 and it does some goofy things in Windows XP they never fixed in the slide show mode.
Jun 10, 2008 | Roxio PHOTOSUITE 5 PLATINUM CD for PC
EZCD 5.0 and EZCD 6.0
I don't think that 6 and 5 are compatible 6 is an upgrade from 5. I have just 5 on one of my old XP computers and it works fine, but that's all I have. I went to the website and they are not giving any support for Roxio 6 anymore.
I will tell you that Roxio Easy Media Creator is fantastic. The things you can do with that are unbelieveable. I got it at Sam's Club for about $70. But I know that does not solve your problem.
Roxio 5
To burn data files, Open project selector, make a data cd, click data cd project. WhenEasy CD Creator 5 opens and you choose your files to burn, try this: Select Disc at Once Radio button, click okay and click burn.
ID Number: 000008GN Products: General Information
OS: Issue When burning a CD or DVD, you receive an error, burning does not complete, or your media is rejected. Resolution Burning errors can happen for a variety of reasons. Roxio has found that doing the following steps resolves about 80% of all burning issues. Please give all these steps a try and see if it fixes your writing problems.
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. The media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  5. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  6. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Roxio 6
OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: EE6000132 Products: Easy CD Creator 6.x Platinum Suite
OS: Windows 98 Second Edition
Windows ME
Windows 2000 Professional
Windows XP Home Edition
Windows XP Professional Edition
Issue Roxio does not recognize the blank CD/DVD media in the recorder drive.
Resolution Follow the listed procedure to ensure that the CD/DVD media you are using is supported by your CD/DVD Recorder.
On Easy CD and DVD Creator:
  1. Open Creator Classic.
    1. Launch Roxio Easy CD & DVD Creator 6.
    2. Click on the Creator Classic icon.
  2. Check the supported media types.
    1. Click on Tools on the top left hand corner of the window, then select Drive Properties.
    2. Under the Devices section, click on your CD/DVD Recorder drive.
    3. Under Supported Media, click on down arrow to see a list of supported media your CD/DVD Recorder supports.
    4. Ensure that media type that you are using is listed here. If it is not listed then your CD/DVD Recorder does not support that type of media.
On Easy Media Creator:
  1. Launch Disc Information.
    1. Launch Roxio Creator Home menu.
    2. Click on the Tools tab, then select Disc Information.
    1. Under Supported Media, ensure the media type is listed.
    • Reboot.
I do know if you have Roxio5 you cannot installed Nero 6 InCD, not compatible. Other than all of the above, I have no more suggestions. I am really sorry, wish I could work on your computer to figure out the problem. This is my specialty. Reloading computer and figuring out problems. It is so much easier hands on.
Good Luck
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
Driver
Download and install adobe reader for manual, if needed
use Get Adobe Reader button on this page
http://www.adobe.com
Manual link (two choose based on directions)
http://www.bushnell.com/customer_service/manuals/binoculars.cfm
There may be no driver required for vista for the USB access to the camera.
However one of the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
This Vista support link may help
http://kb.roxio.com/content/kb/General%20Information/000004GN
This Update is PhotoSuite Version Specific, you will need to find the version of PhotoSuite installed on your system before selecting the update.
To find the version of PhotoSuite that you have installed first open PhotoSuite and then Go To "Help" and then to "About Roxio PhotoSuite", once the About box opens you will find the version at the bottom center.
If you have version 5.1.2529.0 or higher this update is not needed.
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1366.0 only.
Note: The latest Easy CD & DVD Creator Engine update should have already been installed.
(This update will take 5 to 20 minutes to install, there is no progress bar, so you should not interrupt it.)
Download
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1419.0 only.
Download
Update PhotoSuite 7 Platinum to 7.0.430.0 (English Only)
Important Note:
This updater is intended only for the stand alone version of Roxio PhotoSuite 7 Platinum. If your version of PhotoSuite 7 was included with Easy Media Creator 7 then please (use those listed above) for the correct updater.
Download
Dec 22, 2007 | Bushnell ImageView 11-8200 Binocular
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
