Question about Mitsubishi WD-52725 52". Rear Projection HDTV
WD-52725, Denon 1508 and a PS3
Is any of this stuff compatible? I cant get the PS3 to play on HDMI cables. I'm trying to hook the PS3 to the AV Receiver then into the TV. I have also tried to go directly to the TV. Is this TV not compatible with HDMI? Should I just be using component cables?
  • xocobra Apr 29, 2008
    really, so HDMI is not really HDMI on these things? I appreciate it. Guess I'll have to go try those. will ig give decent quality for blue ray compared to hdmi?
    Thank you for your knowledge and time to post up. I will go find some components and see how it works out.
  • 487 Answers
Use the component cables that will be your best bet.
Posted on Apr 29, 2008
  • eric bosman
    eric bosman Apr 29, 2008
    yeah the blue ray will be quite good actually. Good quallity
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
No picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Feb 28, 2010 | Denon AVR-589 Receiver
I have my PS3 and TV hooked up to the HDMI ports. I have programmed the unit to show them under TV and DVD respectivly. When I change the source to TV or DVD, nothing shows up on my TV as expected
Sounds like you hooked them both up to HDMI input ports. Make sure that the PS3 is connected to an HDMI input port on the AVR-1508, and that the TV is connected to an HDMI output port (not an input).
Oct 21, 2009 | Denon AVR-1508 Receiver
I cant get my ps3 to play threw my sony surrond system period the tv is a sony too i have all the hdmi cables hooked up why wont ps3 play on the surround?
You can't get audio from HDMI cables. You have to connect the regular AV cables into your sound system first or you can use the digital output from the PS3 into your sound system if you've got the right cables. You'll also have to configure this through the audio settings. This should solve your problem. Let me know if it doesn't.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
No sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Dec 29, 2008 | Denon AVR588 Receiver
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Denon 1508 A/V receiver; sound but no picture
I would try direct connection using a short SCART lead with full 21 way cable.
Feb 22, 2008 | Audio Players & Recorders
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
