Question about Sony KP-ER43M61 43" Rear Projection Television
Dual picture, dark picture
I have a Sony 42" rear projection TV. It was manufactured in 2000. We are getting a dual picture with a fuzzy line down the approximate center of the screen. The color is also not correct, mostly dark and shadowy. I am pretty sure it is hooked up alright, we recently moved and it has not worked since. It is hooked up with component video cables from a DVD player only, no cable input is connected at this time. Until we moved, the unit worked perfectly. It was handled very carefully and never dropped.
  • stevepeebles Apr 29, 2008
    Yes, I suppose it could be considered like that.
    I can handle the soldering fine, can you point me in the right direction of the convergence IC's?
  • 2,326 Answers
Do you see the video like a 3D image?
Posted on Apr 29, 2008
  • 2 more comments
  • Jaime Hernandez Apr 29, 2008
    Thank you for the info.
    It looks like the convergence ICs are damage or somehow during the move the solder joints around the are became loose.
    If you are handy with a soldering iron, this might be something you can do.
    Please let me know if you need more assistance.
    Check for some instructional videos on You Tube, just google "how to solder" "How to desolder"
    Click here to get more info on the subject and check the hyperlinks as well.
    The ICs that will need to be replace are STK392-020, there are 2 of them.
    I would also suggest to check the 3.15 amps pico/micro fuses nearby the ICs.
Vs 60111 Fuzzy picture
Its a very old set and if happens on all inputs and cables have been ruled out something serious--the rear inputs bypass the tuner in the set and based on its age I would not suggest spending major money (if you can find someone willing to work on a set of this age) on this set.
Many parts for this are no longer available.
Aug 20, 2012 | Mitsubishi VS-60111 60" Rear Projection...
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
Oct 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV took a dump
Sounds like a problem with the Hyper Board.
Dec 13, 2007 | Toshiba 65H81 65" Rear Projection...
Dark Picture on my 5 year old 42H81
Any horizontal or sqiiggly lines in the picture or just a loss of light level?
Nov 07, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42 inch rear projection TV
You likely have a bad hyper board.  As time goes on the lenght of time it takes to get a clear picture will increase and eventually the picture will never clear up untill the part is either repaired or replaced.
Oct 23, 2007 | Toshiba 42H83 42" Rear Projection...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony wega rear projection
Many Sony LCD projection TV's have a problem with optic block failures and your description is exactly what happens. Picture starts turning yellow or green and blotches of yellow or green. Many Sony model have an extended manufacture warranty on these optic blocks and if you get me the model and serial # of your unit I can provide more info.
Nov 13, 2006 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KP-ER43M61 43" Rear Projection Television Logo
128 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
