Question about Olevia LT23HVX 23 in. LCD Television
My olevia LT23HVX does not power on
Last night I was using my olevia as a computer monitor. After done with my work I hit the power button on the remote to turn it off. Today when I try to turn it on, it won't come up. THe LED on the tv is glowing. I tried switching the tv off from the back and removing the cable , but to vain. Please help. I also have the same problem. Unit doesn't come on.
    Novelist:
  • 150 Answers
Are you still using it as a computer monitor, or are you
back to watching television?
1) Make sure that the you have selected the correct
video input for your programming and that you have
a valid video signal connected the corresponding
input.
2) Does the menu come up when you use the remote?
Make sure that the remote is still in TV mode,
not in cable, VCR or DVD modes.
3) Most TV's will blank the screen to black when there
is no input. If you have recently changed the cabling,
e.g. unplugged the computer
the TV may still be stuck in computer mode,
waiting for a valid video SYNC signal to activate
it from a power saving mode.
Some TV's will also not wake up even to display
a settings menu, unless a valid TV signal is present,
due to idiotic design. (This is now rare for newer TVs)
4) Try pressing the MENU button or the INPUT SELECT
button on the remote, to see if the TV responds.
If it does, select the correct video input and you are done.
5) If the TV does NOT respond to the menu button
(on the remote, or on the TV itself)
re-connect the computer and make sure that the
computer is not in STANDBY or HIBERNATE mode.
Press a few keys on the computer's keyboard,
or briefly press the power button on the PC
in order to to wake it up if necessary.
wait a few seconds....
Does the TV come back on ?
if yes, use the settings menu to change the video input
to normal, before disconnecting the computer,
and you are done !
6) Try all the external video inputs, by plugging in a cable box,
VCR, DVD player ... etc
To see if the TV wakes up
If it does, use the menu to select the correct input,
and your done.
7) Leave the TV switch on, but unplug the power cord
for 2 minutes, to see if it resets.
By leaving the power switch ON, you are making sure
that any residual energy in the TV's power supply capacitors
is fully discharged,
in order to make sure a full power-on reset sequence
is initiated.
8) I you cannot get the TV to wake-up or respond by taking
the above steps, the TV is probably defective and you
may need to contact the manufacturer for technical support.
9) I checked the specs on your TV model, and it appears
that the TV is a true LCD monitor, not a rear projection
LCD chip, so there is no projection bulb to burn out.
Martin
Posted on Apr 29, 2008
  • Martin J Stadler
    Martin J Stadler Apr 29, 2008
    Before you look for power supply failures,
    make sure that it's not a simple video input
    problem as I indicated, especially given the
    fact that the power light is on.
    If it is a power supply failure, you can either:
    1) call a tech
    2) check for internal fuses
    3) replace the power supply board
    4) Troubleshoot the power supply board
    by comparing voltages and waveforms to
    a schematic.
    Clearly, electronics expertise is needed at
    that point, and if you had electronics knowledge
    you would have solved the problem already :)
    So I don't recommend poking around on the inside
    unless you know what you are doing.
    LCD TVs do not have high voltages inside like the
    old CRTs, but power line voltages may still be present
    and give you a bad shock.
    Also modern CMOS integrated circuits (or chips) inside
    digital equipment are very(!) sensitive to over-voltage,
    short circuits or even static electricity. The simple act
    of touching the wrong chip with your fingers can destroy it.
    A static shock too weak to give you a tingle, is strong enough
    to blow the integrated circuits inside your TV
    Martin
  • Martin J Stadler
    Finally soldering/ de-soldering modern circuit boards
    requires considerable skill. I have been working with
    electronics for over 30 years :)
    Martin
    President:
  • 2,712 Answers
Hello CarolMae,
Sorry to hear about the trouble you are having with your TV. this seems to be common, though, as seen from the other posts.
This is most likely due to 2 problems -Temperature or a bust capacitor,
1. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use hairdryer., but don't hold the dryer too close(say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Reseting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. If you want to go in for a long term solution, you can easily replace the whole power board (should be about $50 or so). You can call OLEVIA at 1-866-965-3842
or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a pic:
my olevia LT23HVX does not power on - moz-screenshot-1.jpgmoz-screenshot-2.jpg4922492.jpg
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified techie to do it for you.
PS. The capacitors are usually 680 - 1000 micro farad and 16-35V.
You can buy the capacitors online from HERE or HERE if you wish..They cost $0.068 - $0.85 each, depending upon the model.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    post them here.
    Cheers!
    IrishDruid
    Guru:
  • 1,342 Answers
Yes, you are not alone. Seems to be a design flaw. Look Here
Call your dealer or the manufacturer.
    Genius:
  • 3,422 Answers
You will have to call a tech to get it repaired.It is a power supply problem.Anyways once try it using the computer monitor again and see if the TV comes on.
Goodluck..
  • 2,335 Answers
It could be a power supply failure.
Read other member comments by clicking here.
My lt23hvx power button does not work. I keep pressing the power button to turn on and it will not turn on
If you're trying from the remote control, then try from the TV and see if it works. Or vice versa... Also, make sure the TV is plugged in (you would be really surprised to see how often this is a problem).
If there is no noise and no lights, then odds are your power supply is faulty. For that tv, you're looking at a replacement of less than $100.
Cheers, -SJ
Mar 08, 2011 | Olevia LT23HVX 23 in. LCD Television
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia LT23HVX screen resolution
what kind of cable are you connecting with? If you are using a Composite or S-Video cable perhaps you may want to use the VGA cable instead and see if that corrects the issue.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
I have Olevia LT23HVX tv/pc monitor. Im trying to hook it up to my home pc but it keeps on saying OUT OF RANGE under pc. But for the tv is fine can youo help please.
"Out of range" meand the screen resolution of your PC doesn't equal the input possibilities of your screen
Check the resolution is compatible.
Feb 07, 2011 | Olevia LT23HVX 23 in. LCD Television
I need a driver for my LT23HVX Olevia Display
Since this is a TV, you do not require a driver for it or any display device attached to a PC. The driver you need to update is the video card driver of your PC.  Once it is installed, it will be able to communicate with your TV or monitor's EDID (Extended Display Information Data) and be able to send an image to it properly.  The internal EDID will tell the video card what resolutions it can accept.
Mar 24, 2009 | Olevia LT23HVX 23 in. LCD Television
Olevia LT23HVX where to find a power supply for this tv ?
do you have any power if the led is not on on then make sure the switch is on
if its on and no led take it apart and look on power board you will see a fuse use a screw driver with a rubber handle jump across and see if it works then if it does goto radio shack and get the same fuse slow blow fuse
Jan 25, 2009 | Olevia LT23HVX 23 in. LCD Television
Olevia won't turn on.
I posted photos and a description of my solution for this problem here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/ There's another thread on FixYa dealing with this same issue that has a variety of solutions as well.
Mar 04, 2008 | Olevia LT23HVX 23 in. LCD Television
If you want to see photos and a description of the disassembly process and commentary on my repair job, soldering in the new caps, etc. I've posted them online for anyone interested in tackling the job themselves. I've never cracked the case on a TV before, but thanks to some of the hints here, and some efficient Googling, I was able to fix my own set with a screwdriver, pliers and a cheap soldering iron, all for less than the price of a pizza.
Nov 01, 2007 | Olevia LT23HVX 23 in. LCD Television
Power indicator on, but nothing else
Plug a cell phone charger in the service port on the back. The charger does fix the power problem. I did contact Olevia tech support after 2+ hours on the phone and they had not heard of the charger solution and did not recommend it but when the warrenty is out "what the hey". They did sell me a new power board which I installed and that fixed the problem. $50 and return the old one. Need to be familiar with computers or electronics to do yourself.
Sep 27, 2007 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
190 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
