Question about HP Officejet Pro L7780 All-In-One InkJet Printer
HP L7780 The printer has started to print with yellow streaks through the black? I have cleaned the printheads, realigned, calibrated, don't know what else to do.
    Novelist:
  • 85 Answers
Clogged Inkjets? Could they be white Lines in your prints? Assuming your inkjet printer worked OK before a period of non use? And you do not have any strange flashing lights, or an obvious electrical fault or malfunction?
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like WARMED Magic Inkjet Flush
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realising the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and WARMED Magic Inkjet Flush injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Hope this helps to explain.
Posted on Jun 03, 2008
Officejet pro l7780 not printing
OfficeJet 7880 Not Printing
A little more information would have been helpful in troubleshooting this problem. Did the printer ever work correctly? Did it just start printing yellow lines one day? Has it been out of use for a long time or, did you buy it in this condition. Also, is your computer a Windows PC or a Mac and which version of the OS are you using?
If you don\'t have the manual, you need to download one. I saw a link in a previous post or you can go to HP.com. The manual is crap as far as troubleshooting but it has all the part numbers of ink cartridges and printheads.
From the skimpy info you have supplied, I am going to assume there is something wrong in the ink supply system.
1. First you need to print a test page to find out if anything other than yellow can get to the paper. Find the HP Printer Utility. Again, not knowing what computer and OS you are using, I can\'t give you any explicit info. On Windows you might find something in Control Panels>Printer or under Programs you might find the HP Printer Utility. On a Mac maybe System Preferences>Printers or Go>Applications>HP Control Center.
2. If it only prints yellow boxes, or yellow boxes with streaks, you can run the Clean Printheads utility and reprint the test page. If you get more yellow or other colors start to show up, this indicates there\'s something wrong in the whole ink supply chain.
The HP 7xxx printers use the CYMK color system and have separate ink cartridges for each color: cyan, yellow, magenta, and black(K). In addition, the printheads are separate from the ink cartridges: yellow/black printhead and cyan/magenta printhead.
3. The problem could be in the ink cartridges or the printheads, or both. If the printer has been sitting for a long time, the ink will gel and clog up the whole system. Check the ink cartridges first. Are all four of them installed? Are they HP brand? Take them out one at a time, shake them and the reinstall them. Print another test page. Did anything change?
4. If more colors are printing, even with streaks, you should probably replace all the cartridges with GENUINE HP cartridges that are not expired. This could cost you $50-$60 on an eBay purchase but if you buy non-HP, or expired cartridges, you will not be a happy camper, long term. If you want to do this on the cheap, buy a black cartridge and see if you can at least start printing text. If you\'re making progress, you can buy the color cartridges later.
5. If replacing the cartridges fixed the problem, you\'re home relatively "free". If you have to replace either or both of the printheads, this can be expensive. They can run from $50-$100 each, so you\'ll have to make a decision on how much you want to spend on a printer that sold for $175 at Costco 6-7 years ago. Don\'t get me wrong, this is one of HP\'s better print engines but you will have to make an economic decision based on how much it\'s going to cost to bring this printer back to life. You can probably pick up a used 7xxx printer on Craigslist for $50-$75.
Hope this helps.
Sep 22, 2014 | HP Officejet Pro L7780 All-In-One InkJet...
The following printhead has a problem black/yellow the printer will not print. These are new ink cartiladge
Hello and welcome to FixYa!
In the HP OfficeJet Pro L7780 the printheads are actually separate from the ink cartridges. In your case, it sounds like the black/yellow head has worn out and will need to be replaced. The good news is, this is a user replaceable part. The bad news is, the replacement heads are not cheap. Amazon has the HP 88 Black/Yellow printhead listed currently for about $61.
http://www.amazon.com/HP-Yellow-Officejet-Printhead-Packaging/dp/B000BO9L8M/ref=dp_cp_ob_e_title_0
YouTube has a nice video that explains how to install the printheads here:
http://www.youtube.com/watch?v=8Zl0LUxBSvg
I hope this helps!
Mar 02, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Alignment of HP L 7780 failed. What are the steps to correct?
hello, you will need to run a cleaning cycle, you are looking for black printing, if not printing well, it might fail, if it does you will need #88 printhead. the black/yellow one. most times you will not need calibration to print, unless machine is stuck in that mode and won't pass. and won;t allow for print.
Oct 25, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
How do i clean the printheads on a hp officejet
hp printers have a utility program that cleans and purges the printer heads. Go to HP on your startup menu and look through the options....mine is located in the "hp solutions center".
It has an option for purging the printer heads.
Jul 07, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
290 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
