Question about HP 4250 Monochrome LaserJet Printer
Cannot print odd-sized envelope with 4250 LJ
The printer has an envelope feeder attachment. When we print on standard-sized envelopes, it works fine. We are trying to print an odd-sized envelope (Avery A7). The feeder will not grab the envelope; it doesn't even try. In the Envelope Size option on the printer, we have it set for "Any Size", as there is no "A7" option there. Any ideas?
  • eric bosman
    eric bosman May 11, 2010
    do you have it in your printer prefferences selected as size?
We are using standard size envelopes and the default used to be drawer one. Now if we have envelopes in the manual feed it wants to pull from there no matter what we select.
Posted on Aug 13, 2008
I got to HP tech support, and they tell me that the envelope feeder is intended only for a few standard envelope sizes. If we're trying to use a different sized envelope, as in this case, it must be fed manually, and the feeder bin will not work. So that answers that. Thanks for the help, though.
Posted on Apr 30, 2008
My hp J4680 won't feed envelopes, the envelopes goes part of the way in and then fails to print
Hi
The envelopes are standard in size hence do not use any odd sizes. And also do remember that you make the required alignment and also the feeding directions and positions. If you print in Landscape then the paper is too short for the printer to pick. Hence use Portrait so your printer can sense the presence of the envelope
Jul 16, 2011 | HP J4680 Office Jet All-In-One Printer
Hp 4250 laster jet toner not adhering when printing envelopes. Seems fine for 8 1/2 x 11 paper. Only happens with envelopes
Try this:
Check the printer configuration pannel in your computer.
Select papper size(envelopes) and change the weight.
Jun 27, 2011 | Office Equipment & Supplies
HP Laserjet 4200 with optional Envelope Feeder will not automatically pull #10 envelopes from Envelope Feeder?
Use a damp lint free cloth and clean the feeder rollers.
Print out a configuration page to make sure that the printer recognizes that the feeder is installed.
Usually the envelope feeder problems stem from age and/or dirty rollers.
Make sure that your software app sees that the feeder is attached.
Feb 08, 2011 | HP LaserJet 4200 Printer
How to print a envelop
find ur envelop size.
setup ur page in word
type the address
print
Aug 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have an envelope feeder that came with my old LaserJet 4 many years ago. I replaced the LJ 4 with an LJ 4-Plus and tried to use the envelope feeder on it. I get an immediate error message "EE...
My suspiction is there is a tab on the tray that triggers a switch telling the printer what type of tray has been inserted. Your old tray is likely different from the Plus 4 tray and the printer knows it.
Jun 04, 2010 | HP LaserJet 4 plus Printer
4250 HP. Loses settings. Correct to show envelope
In the paper-handling menu set the envelope feeder size to the size of your envelope and the envelope feeder type to *any type.
Then ensure you are printing envelopes from your application.
Nov 25, 2009 | HP LaserJet 4350 Printer
Printing Envelopes
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My printer willnot print envelopes.It states paper size or type is incorrect. On all sizes.
Some printers have an extra feeder under a door on the front or side which allows you to insert an envelope. These types usually will not rcognize an envelope when inserted into the sheet feeders.
If you are using Microsoft Word, you may be able to do it from the "Tools"/"Envelopes & Labels" tab, but you more likely need to find the envelope feeder on your printer, if it exists.
Good luck !!
Oct 10, 2008 | HP Office Equipment & Supplies
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
How to print #10 Envelopes
How to copy/print onto envelopes.
Solution
Konica Minolta does not recommend copying/printing onto envelopes, asthe MFPwas not designed to run envelopes. Additionally, envelopes do not meet the
standards set for paper specifications. Their multi-layer make-up, adhesive, and odd size make it unreliable and potently damaging to the MFP.
Nov 13, 2007 | Office Equipment & Supplies
HP 4250 Monochrome LaserJet Printer Logo
512 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
