Question about Dryers
LG dryer, keeps asking me to clean filter, I checked the door lint filters & the condencer?? any idea
Hi my dryer no longer gets hot enough to dry my clothes without
having to run it for almost 2hrs for one load...this is a big problem..
can someone help me find a answer on model# DC-382WD. I search this model and it tells me it doesn't exist???
thank you,
Posted on Apr 29, 2008
My lg 2240 clean filter light blinks even though the filter is clean. when started it runs for 3 to 4 seconds then shuts off. if you wait for about a minute it will start again then shut off after 3 to 4...
This problem usually is caused by a restricted or blocked vent. The filter itself can be clean, but the duct work in the dryer after the filter, or the vent hose attached to the dryer, or the exhaust door attached to that hose is either restricted, plugged or blocked. Lint likes to build up in all areas the exhaust air goes, so check them all. The dryer has a sensor that will shut the dryer off if there is a restriction. Cleaning all of the duct work, from the filter all the way to where it exhausts outside, will usually solve this problem. An easy way to check is to unhook the exhaust hose from the dryer and run it. Does it keep running now? It is possible the sensor in the dryer has gone bad, but that is rare. 99% of the time it is lint build up in the venting.
Dec 12, 2013 | LG WM-2277HW Front Load Washer
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
I have a lg tromm dle2514 dryer and the check filter light is on. I am willing to clean it (I've already cleaned the front filter area) I just have no idea where there is another filter
There is no other filter to clean other then the one lint filter.
I would check the dryer vent to make sure it's not restricted with lint build up or has any kinks in it. Also check the outside flapper at the end of the dryer vent to make sure it's clear of lint and able to open all the way.
If your dryer vent is ok and the lint screen is clean then I would remove the front of the dryer and check the blower/fan housing for lint build up.
Aug 04, 2011 | Dryers
Our LG DLE0442W electric dryer is now flashing the Check Filter light and will start, but only run for about 5 minutes before shutting off. I have cleaned the lint trap completely and have also tried...
Clean any lint that got by the filter as best you can. If you can, get into the housing that surrounds the filter and clean it, but be careful not to damage the moisture sensor.
Check that the duct (behind the dryer) is clear of excess lint and has no obstructions (kink, bird's nest, etc.).
Good luck
Feb 21, 2011 | LG DLE0442 Electric Dryer
Dryer keeps saying check filter - lint screen is clean-dryer won't run
Had the same problem. Filter was clean. Vacuumed out the area under the filter. Still had problem. Unplugged the dryer. Removed the hose vent (back of dryer) and checked the exhaust -- all clean. Plugged the dryer back in and was fine. Still going to check the vent to the outside for lint buildup.
Jan 17, 2011 | LG DLG2524 Gas Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Jun 06, 2010 | LG DLE5955 Dryer
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
I have a large capacity front load LG electric dryer. I keep getting the "check filter" message & the filters are clean. The dryer will not stay on. HELP!
The message does not only refer to filters, badly written.
There is an air flow restriction that the machine senses and is warning about.
check the fan and fan housing for lint that has got past the screens, then pull the dryer away from the wall and check the exhaust duct for lint, all the way to the wall
then check the outside wall vent for lint build up in the rodent screen
before clean
239f28d.jpg after clean
a605f7e.jpg no clean
Oct 10, 2008 | LG Dryers
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Dryers Logo
112 people viewed this question
Top Dryers Experts
