Power window problems on 1997 chevy venture van
Passenger side widow goes down but not up. A new motor was installed but only goes down. I think when you push the switch forward the window should go up but it goes down pushing forward. Drivers side is sluggish and goes up and down but forward on the switch makes the window go down.
    Problem Solver:
  • 9 Answers
Sounds to me like the switch on the passenger side is broken or the wiring is wrong or a plug has come off, use a screwdriver with a cloth and pop out the switch and check the wiring and plugs.
Check eBay for chevy switch's
Posted on May 01, 2008
Chevy venture van passenger side AC blows cold, driver's side blows warm to hot
Usually a blend door problem, either the control or the blend door itself.
Jul 03, 2012 | 2000 Chevrolet Venture
My 2001 venture van passenger power window will power down, but not up....driver switch has no response now to passenger door window ?
Now you do not have any response at all up, or down ?
I would say fuse has been blown to that side, but the bigger problem is that I believe the window motor more than likely has failed.
You will have to remove the door pad and using a volt meter find if you have 12 volts to the motor while operating the switch.
If you have 12 volts, then I would say motor is bad.
If you do not have 12 volts, then I would trace wiring back to switch, look for continuity.
Please let me know what you find.
Feb 10, 2010 | 2003 Chevrolet Venture Passanger
Solution for ''1997 chevy venture power window wont work
I have the same problem mine is in the switch my drivers side switch only works when I wiggle it the passenger side works fine probably a broken wire in the switch
Aug 23, 2009 | 1997 Chevrolet Venture
My power windows won't go up or down in my 2005 chevy venture mini van, both drivers side and passenger side controls won't work fuses are all good, whats going on???
possible switch maybe both motors are bad get a meter or test light check for power and ground at the switch and at the motor
Jul 10, 2009 | 2005 Chevrolet Venture
Power window not working
window motor or window regulator. glass could also be off track.
Apr 26, 2009 | 1999 Chevrolet Venture
2005 Chevy Cavalier Electric Window Wiring Diagram
Tom,
See this alot. Sorry,It appears that is a symptom of a bad motor. If it moves an inch or so,then nothing,after a few minutes another inch or so,it's motor time!
Apr 08, 2009 | 2005 Chevrolet Cavalier
Chevy Venture Passenger side windo won't roll up
wiring harness on passenger door has a severed wire
Mar 15, 2009 | 1997 Chevrolet Venture
Passenger power window powers down not up
If you can do it, run a jumper from the drivers door to the passenger door. Unplug both motors. try to run the passengers door off the drivers switch to rule out the motor. I don't think it is because the motor is dc. But this is the common point. Please mark this as helpful or fixya. Shuold you have anymore problems, I used to be a mobile mechanic electircian. Looking forward to hearing from you.
Dec 31, 2008 | 2004 Chevrolet Venture Passanger
Chevy Venture power windows- 2003
It is possible that it is the fuse but if so something caused the fuse to blow. It may be in the wiring which if you pull up the carpet by removing the door floor trim and lifting the carpet you will see the wiring underneath. Probably laying in water. Look for splices in the wiring which will have corroded. Repair the wiring then replace the fuse.
Another problem may be in the motors found inside the doors. The brushes may have worn out. If so you need to replace the motors. Unlikely that both motors failed at the same time though.
Usually the drivers door first since it is the most used.
Dec 17, 2008 | 2003 Chevrolet Venture Passanger
I have an 04 Venture and the drivers window goes down but not up. I replaced the motor, plugged it in, and it run down but did not return up. I have power to both brown and blue wires going down and up,...
sounds like your switch,,,, theres a problem with some that bind on the weather stripping guide in the inside of the doors ,, but i think it might be the switch ,, get a used one at the junk yard ,, other models have the same switch ,, olds vans and so on
Jul 28, 2008 | 1997 Chevrolet Venture
Computers & Internet Logo
484 people viewed this question
David Payne
David Payne
