Printer says error and 5 docs waiting - Office Equipment & Supplies
  • 487 Answers
On the bootom of your screen there will be a little printer with a red cross. right click and say open active printer. Cancel all print jobs.
and reboot computer. turn printer off for 30 min and you most likely have no more problems
Posted on Apr 29, 2008
510 ERROR LL12
LL.-- Switch the printer off. Wait several seconds. Then switch the printer on.
Here's the manual:
Oct 24, 2017 | Office Equipment & Supplies
My deskjet 5940 won't print a document or test page. status: Error sent to printer doc
Unplug your printer from the power source. wait 20 minutes and then plug it back in. See if that clears the error message.
Jun 26, 2017 | The Office Equipment & Supplies
Hp laserjet pro 400 m401n printer 59.A0 error
59.X Error Turn off then on
The product has experienced a problem with one of the motors.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
Apr 20, 2016 | HP Office Equipment & Supplies
My canon mp 560 is reporting error 5b00. What does that mean?
press MENU button, SCAN button, COPY button, SCAN button.
wait a minute.
it may be enter into special mode: service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 19, 2011 | Canon MP560 All-In-One InkJet Printer
How to solve error is doc. feeder jam in hp laser jet m 1522 nf
Hello Anil_ kuma61!
First thing you need to do will be check the correct postioning of the pick up roller on the automatic document feeder, open up the top cover, you will see a grey roller on the middle, this roller shouldnt be touching the cork a the bottom.
After checking on this, we need to reset the sensors on the printer, to do this follow this steps:
1) Turn the printer off
2) Take out all supplies, including toner and paper
3) With the printer off, press the down arrow and the cancel at the same time (keep the depressed)
4) Turn the printer on while holding those keys and wait until you a message on the display "permanent storage init"
5) release the keys and wait to the printer to come back to ready
Jan 22, 2010 | HP LaserJet M1522n MultiFunction Printer
My esp5 all in one printer says there is an error a paper jam but there isnt one please help
1. Take out both the ink cartridges, wait for 5 seconds.
2. Take out the printhead, and close the printer access door
3. Take out the power cable without turning OFF the printer, and wait for 30 seconds.
4. Now connect the printer with the power cable, and turn ON the printer.
5. If the printer is giving an error” printhead missing”, now put the printhead back.
6. Closing of the printer access door brings up error message “missing cartridge.”
7. Insert both the ink cartridges into the printhead.
8. Close the printer access door, and wait until printer gets ready for printing.
9. Give a print command after loading paper in the upper tray.
Best of Luck
Oct 27, 2009 | Kodak ESP 5 Printer
Does anyone know what error code 3807 on a Kodak ESP 5 all in one is? And....can anyone tell me why the dammed thing tells me the print head is not installed every time I turn it on?
found a solution for your error code 3807 "System status failed"
To resolve the error condition:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
  4. Wait until the printer is ready to use.
If the error condition continues:
  1. Remove and install the Printhead two times before closing the Printer Access Door.
  2. Wait until the printer is ready to use.
If the error is not resolved, contact Kodak.
Jun 21, 2009 | Kodak ESP 5 Printer
Scanner error 6
Scanner errors are as follows for that model:
Scanner error #
1 = dark find
2 = LMW temp find
3 = bulb warm up from off
4 = bulb warm up from coarse
5 = cal label find
6 = doc original find
7 = LMW final find
8 = cal label find after scan
9 = cal label find prior to standby
10 = doc original find prior to standby
11 = bulb warm up from standby
I would see if there is an original on the flatbed glass (platen), or if something is obstructing the scanner view.
If the error persists, replace the scanner
assembly or the formatter pcb
Apr 22, 2008 | HP LaserJet 2840 All-In-One Printer
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
55 people viewed this question
