Question about Olevia LT27HVX 27 in. LCD Television
No picture or sound
GE 27" - no picture or sound
Olevia multi function tv/monitor hdtv
No picture, no sound. Indicator light is on. Checked cable, power, tried to move back to computer. Nothing works
  • justino31 Dec 13, 2008
    I have a V227 Olevia tv and all of a sudden there is no picture or sound. The blue indicator light is on. When i turn the tv on it has a black screen and there is no sound. I've had the tv since July of 2007 without a problem until today. I tried upgrading the fimware also and that didnt work either. Why is this happening?
  • Anonymous Feb 11, 2009
    Olevia is 1 and 1/2 years old, suddenly a black screen and it won't turn on. There is power but it wont respond at all.
  • 3 Answers
On mine the indicator light is indicating that it is in STANDBY mode, which means it is OFF. Press the button again, which will turn off the light and now the tv is ON. Now merely press(possibly multiple times) SOURCE to find the correct source for your Cable/SAT and your good to go.
Posted on Dec 30, 2008
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
kolbrun
Feb 01, 2015 | Olevia Televison & Video
No sound coming from tv
Replace the main board audio signals are produced by the main board. You can get the replacement main board from www.tvrepairworld.com
Oct 04, 2012 | Olevia LT27HVX 27 in. LCD Television
I HAVE AN OLEVIA HDTV MODEL 232513 IT DOESN'T TURN ON
Check the power source?Have power to the tv at all?Power LED light incation flashes?Yes?That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 21, 2010 | Olevia LT27HVX 27 in. LCD Television
My TV says NO SIGNAL on tuner...
yes, you may be lucky to just to burnt one of the source/input mode try switching them.
for example use a video cable instead a coax if you still dont get a signal that means the picture uotput board is damage by the storm.
Aug 15, 2009 | Olevia 227-S11 27 in. LCD TV
Sound but no picture. menus work.
I had the same problem. In the menu, the image button was grey, and could not be hi-lighted, and the screen stayed blue. I was using the AC power cord. I plugged in the DC power cord instead, and it "woke" the unit up. I switched back to the AC power and it works fine. If you don't hve the DC cord that came with the TV, try andy 12 volt dc output cord with a positive tip.
Jul 12, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
Olevia tv
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Apr 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Turns on, i can hear sound and backlight turns on but no picture.
try this , an unrelated solution for power problems
I think this model has a timer on it, it seems to go when the warranty runs out, not proven but Mine went out about a month ago. My only fix is to plug my tv (via the service port which is COVERED) to the usb port on my computer using my BlackBerry usb cable, in other words the Mini USB. Seemingly I must be logged on to do so and wait for the Chime form my pc, a balloon will pop up for new hardware not recognized (vista) then press the power button and then it turns on, unplug the usb cable and make sure the source is set to tv / video or else it will power back off and you will have to start all over. Theres NOT A PERMANENT fix yet but this is what I do every time I want to use the TV, I have a laptop so I use it as the Monitor just to watch movies. If you have a desktop I recommend keeping the cable handy BUT DO NOT LEAVE THE USB CABLE IN FOR LONG USES. THE SERVICE PORT IS COVERED FOR A REASON!!!
Apr 04, 2008 | Olevia LT37HVS 37 in. LCD HDTV
No picture or sound
Phillips Magnovox 50in I have an indicator light but no sound or picture. Any idea what the problem.
Feb 02, 2008 | Sony KV-27S20 27" TV
QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Dec 31, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia LT27HVX 27 in. LCD Television Logo
263 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
